25
Since a few days ago my Gnome-keyring daemon hasn't been starting up properly.
After logging in:
ps aux | grep keyring
user       3496  0.0  0.0 214408 15800 ?        SLl  13:30   0:00 /usr/bin/gnome-keyring-daemon --daemonize --login
Apps complain about not being able to access the keyring (and fail to do so), some shortcuts are very slow CTRL+ALT+T for terminal or Print screen can both take up to a minute between key press and action)
Seahorse does not show the login keyring
$ /usr/bin/gnome-keyring-daemon
SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
$ ps aux | grep keyr
user       8524  0.1  0.0 211004 12468 pts/5    SLl  13:38   0:00 /usr/bin/gnome-keyring-daemon
Then, as soon as an app wants to access I get the keyring password prompt. Once unlocked, the keyring works properly.
I had a look to startup apps for my session and I only have one command that is relevant:
/usr/bin/gnome-keyring-daemon --start --components=ssh
I added /usr/bin/gnome-keyring-daemon to startup apps, but it will prompt for the keyring password after each login, which wasn't happening before.
Any idea on what happened and how to fix this please?
Zanna
  • 72,312
Laurent
  • 666
6 Answers6
18
I'm facing the same issue,
as an temporary solution try to run the following after login
gnome-keyring-daemon --replace --foreground --components=secrets,ssh,pcks11
When I'm doing this it prompts me to enter my secret to unlock my keyrings.
rkok
  • 103
13
I could work around this problem by uninstalling dbus-user-session (and its dependendants xdg-desktop-portal and xdg-desktop-portal-gtk). Those packages came in through installing flatpak.
Thanks to Olaf who brought me on the right track (https://forum.ubuntuusers.de/topic/gnome-keyring-daemon-doppelt/)
decocijo
  • 288
I've been able to fix the slow shortcut and hanging chromium, by commenting out one line in /etc/pam.d/lightdm
# session optional        pam_gnome_keyring.so auto_start
The issue seems to affect more users btw: https://bugs.launchpad.net/ubuntu/+source/gnome-keyring/+bug/1689825
I had exactly the same problem. Basically, whenever I started up, I could see the gnome-keyring-daemon as a process (ps -ef | grep keyring). If I manually issued the gnome-keyring-daemon using --start option, it would not start up the one fault instance already running. By a process of manual deduction, I found that if I killed that process and started a new keyring, then everything worked perfect. so here is what I did to make the solution "sticky"....
go to menu - system configuration - startup apps
delete the gnome-keyring-daemon entry that is already there (if you have one)
create a new gnome-keyring daemon with the following properties:
Name = Gnome Keyring Daemon
Command = /usr/bin/gnome-keyring-daemon --replace --daemonize --components=pkcs11,secrets,ssh
Comment = Gnome Keyring Manager Daemon
Save the startup item, but make sure it has a small delay - I added 10 seconds, and set the option "On"
Now Reboot, and it worked flawlessly for me. It seemed to be the --replace and --daemonize settings that made the difference on my VirtualBox Mint 18.3 cinnamon and a Lenovo G710 Laptop, having tried various combinations of other suggestions on here.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
This can also happen if you are using apparmor and somehow (updates, something else) apparmor stops getting run on boot. You will get messages about gnome-keyring-agent not being able to allocate secure memory. Starting apparmor, logging out and logging in again fixes it temporarily, re-enabling apparmor on boot with systemctl enable apparmor and rebooting fixes this permanently (if that was your problem!).
AntonOfTheWoods
  • 834
  • 15
I ended up here because of the following errors in my logs.
Mar 11 11:14:32 debian systemd[1899]: Failed to start app-gnome-gnome\x2dkeyring\x2dssh-2092.scope - Application launched by gnome-session-binary.
Mar 11 11:14:32 debian systemd[1899]: Failed to start app-gnome-gnome\x2dkeyring\x2dsecrets-2098.scope - Application launched by gnome-session-binary.
Mar 11 11:14:32 debian systemd[1899]: Failed to start app-gnome-gnome\x2dkeyring\x2dpkcs11-2094.scope - Application launched by gnome-session-binary.
I could fix them by a slight modification of decocijo's answer.
In /etc/xdg/autostart/ I could find the following three files
-rw-r--r-- 1 root root 8608 Mar 11 11:49 gnome-keyring-pkcs11.desktop
-rw-r--r-- 1 root root 8136 Mar 11 11:49 gnome-keyring-secrets.desktop
-rw-r--r-- 1 root root 6671 Mar 11 11:50 gnome-keyring-ssh.desktop
on each of them comment and add one line, as for example in gnome-keyring-pkcs11.desktop
#Exec=/usr/bin/gnome-keyring-daemon --start --components=pkcs11
Exec=/usr/bin/gnome-keyring-daemon --replace --daemonize --components=pkcs11
do the same with the other two files.
I am mainly writing this answer so that other people with these errors can find the answer but ultimately, this should not happen. I have a clean installation of Gnome 43 on Debian Bookworm.
