I'm on a two monitor setup. Its very annoying that when I type Alt+F2 to start krunner it always is displayed on the left upper corner of the left monitor. My main monitor is the right monitor and if I'm on a program on this montitor and run Krunner, its very annoying. Does anybody know what to do to solve this?
Asked
Active
Viewed 651 times
I had the same problem and found a solution, very similar to this one: https://superuser.com/a/1075753/288688
You can create a rule for the krunner window: System Settings > Window Behavior > Window Rules > New...
For Window class (application) you select Exact Match and enter the name krunner. On the Size & Position tab, you enable Position with Apply Initially.
Now here comes the trick: For the first coordinate, you need to enter a number larger than your left screen's horizontal resolution. This way, the window will appear on the right screen. The point is that your multimonitor setup counts as one big screen.
For example, I entered 2600,0, and after clicking on OK and Apply, my krunner appears neatly on the right screen.
Edgar
- 773
- 8
- 11
