I installed a second hard drive (actually a SSD) onto my Windows 7 machine for the purpose of using Ubuntu via virtual machine -- and hated that. So, I tried to install Ubuntu to the second drive and after running boot-repair numerous times I got it running pretty well.
But the GRUB was installed on the C drive, and I don't want to wait the 10 seconds for the GRUB to come up, because I might need to take out the second hard drive and replace the DVD space it is taking. Can't I just boot either straight into Windows, or have the option of Ubuntu or Windows depending on the BIOS setting?
I fixed the Windows 7 boot loader on the C: drive by following the directions on another post, but now I can't seem to get my second hard drive to become bootable by itself, that is, when I set it highest in boot priority.
How do I make the second hard (containing Linux) bootable without having to choose an OS every time I boot up? I'd like my machine to look and behave like a straight Ubuntu machine when the second hard drive is put highest in boot priority, and I'd like my machine to go straight into Windows when the first hard drive is highest. But, I've already installed Ubuntu, and it doesn't seem to boot, even when the priority is set to it. I'm guessing because it previously depended on GRUB?
The only way I can even look at my second hard drive is by booting up via an Ubuntu flash drive. All of the answers refer to GRUB. Isn't there any way to make a drive bootable without GRUB?
It seems that what I'm trying to do is a less-traveled road, but actually a simpler road. Is there a command to make a disk that has Ubuntu already installed bootable?
I ran Boot-Repair again to create a boot-info-summary, here is the report: http://paste2.org/UabY55xE
It appears that you have two HDD's, on one HDD Windows7 is installed and on the other HDD Ubuntu is installed. It also appears that your system is set up in legacy-mode. On the drive where Windows is installed you reinstalled Windows boot-loader in the MBR of the drive already. Now you need to install Grub to the MBR of the drive, where Ubuntu is installed.
To do that you have to boot from a live USB, choose Try Ubuntu, then open a terminal and run the following commands:
sudo mount /dev/sdb1 /mnt
for i in /sys /proc /run /dev; do sudo mount --bind "$i" "/mnt$i"; done
sudo chroot /mnt
sudo grub-install /dev/sdb
sudo update-grub
exit
sudo reboot
Note that in this commands sdb1 means the partition, where Ubuntu is installed and sdb means the HDD where Ubuntu is installed. You have to examine your system and change these values accordingly.
After Grub has been installed, boot to BIOS-setup and change the boot-order to the Ubuntu-drive in the first place and the Windows-drive in the second place.
Related: How can I repair grub? (How to get Ubuntu back after installing Windows?)
Edit
The boot-info-summary looks good so far, found a small bug in line 416 (this is related to /etc/fstab and sdb6. Compare with line 516). Fact is, that Grub is now installed in the MBR of the second drive, and when we boot to this drive, Grub should be booted (even if Grub is not correctly configured or, for example, the Ubuntu-partition was deleted), in the worst case it should boot to Grub-rescue.
I think, booting to the MBR of a HDD on the slot the drive is connected to is just not supported by your BIOS. I've been confronted with this on several laptops. Check manual of your hardware if you can find any information. If this is the case, you can't achieve the bootloader-configuration you described, you will need the boot-loader in the MBR of sda and this boot-loader needs to be able to boot both Os's. This is normally Grub.
IF you keep your current partition-layout and install Grub on the first drive (sda) you will boot to Grub-rescue as soon as you removed the second drive because Grub can't find it's configuration-files which are stored on the removed drive. You would need an external DVD which you connect via USB if you need to work with DVD.
The other way around is to change the partition-layout and install both OS's on the first drive (sda), using the second drive as a pure data-storage. This way you are independent from the second drive during boot, you could replace the second drive with your DVD.
However, you can configure Grub in many ways (default-boot, hidden menu,...). The configuration is stored in /etc/default/grub and you can edit this file with root-privileges (i.g. sudo nano /etc/default/grub). Look for the lines with
GRUB_DEFAULT=
GRUB_TIMEOUT=
and change the values for this entries to set the default menu-entry to boot and/or hide the Grub-menu (`GRUB_TIMEOUT=0). See detailed information in the Grub Manual.
mook765
  • 18,644
