11
I can't enable lock screen mode in my laptop and also in my PC. I went to system setting > screen > lock Ctrl+Alt+L : Nothing happens! the shortcut is there but not works !
sudo apt-get --reinstall install gnome-screensaver :
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 dassault-systemes-draftsight:i386 : Depends: sendmail:i386 but it is not installable
                                     PreDepends: libdirectfb-extra:i386 (>= 1.2.7-2) but it is not going to be installed
                                     PreDepends: libxcb-render-util0:i386 (>= 0.3.6-1) but it is not installable
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Jorge Castro
  • 73,717
mahdiar
  • 846
Ctrl+Alt+L
The above keyboard shortcut will lock your screen.
jrg
  • 61,707
10
I installed ubuntu tweak . go to the "Tweaks" part and then to the "Security related" . Then unchecked "Disable lock screen " ! Thats it !
mahdiar
  • 846
I was reading around & saw that some computers if CON+ALT+L doesn't work to try the "Windows" botton + L (the button with the little Windows logo, if that's the type of computer you're using) WIN+L ---> It worked on mine, I couldn't find the shortcuts mentioned above so I tried this & it worked! Good luck!!
Vanna
  • 81
Try screensaver command, and see if this is the keyboard (shortcut) or the application (graphics function) that is not working:
gnome-screensaver-command -l
Also check shortcut: (should be Ctrl-Alt-L )
>> System Settings >> Keyboard >> Shortcuts >> System
  Lock screen                                  Ctrl+Alt+l
david6
  • 14,528
  • 38
  • 46
