I have a Dell XPS 9360 on which I have just installed Ubuntu 16.04.
It has a QHD+ screen (3200 x 1800) and I'm connecting a second FHD monitor (1920 x 1080). It is connected via USB-C and a 4K -> HDMI adaptor + cable.
I am using "Displays" to set my resolution and to set "Scale for menu and title bars".
I would like to have both screens set to max resolution with the QHD+ screen scaling set to 2 and the FHD screen on 1 (default).
I have not found any method of achieving this goal and I'm currently restricted to FHD on both screens.
Does anyone know if it's possible to set different scaling for each monitor based upon the resolution?
If this is not possible, would it then be possible to write a script that will alter the resolution and scaling to the same values for both monitors when I connect / disconnect the monitor?
icc97
  • 761
Ubuntu101
I've answered this on a question that is effectively the same as this earlier question about huge scaling on a monitor
You need to use the Wayland windows system which allows for independent scaling of the in-built display and the monitor.
Wayland is available in Ubuntu 17+. You can switch to Wayland at the login screen and then adjust the scaling in the 'Screen Display' settings.
I've also asked a separate question about issues with Wayland.
icc97
  • 761
