So I have the specific WLAN adapter as mentioned above (168c:0042 rev 31) but I can't find my WiFi in the list of WiFi networks if the channel is set to 13 (If I set it to < 13, I can find it but there so many WiFi networks on the other channels and they just mess up with mine and download speed gets really slow). I have set my region to my corresponding region using sudo iw reg set (I am fairly sure channel 13 is supported) but the problem persists. I was wondering if the source of the problem are any drivers (currently using ath10k).
EDIT 1:
Output of iw list | grep Freq -A14:
Frequencies:
            * 2412 MHz [1] (20.0 dBm)
            * 2417 MHz [2] (20.0 dBm)
            * 2422 MHz [3] (20.0 dBm)
            * 2427 MHz [4] (20.0 dBm)
            * 2432 MHz [5] (20.0 dBm)
            * 2437 MHz [6] (20.0 dBm)
            * 2442 MHz [7] (20.0 dBm)
            * 2447 MHz [8] (20.0 dBm)
            * 2452 MHz [9] (20.0 dBm)
            * 2457 MHz [10] (20.0 dBm)
            * 2462 MHz [11] (20.0 dBm)
            * 2467 MHz [12] (20.0 dBm)
            * 2472 MHz [13] (disabled)
            * 2484 MHz [14] (disabled)
        Frequencies:
            * 5180 MHz [36] (20.0 dBm) (no IR)
            * 5200 MHz [40] (20.0 dBm) (no IR)
            * 5220 MHz [44] (20.0 dBm) (no IR)
            * 5240 MHz [48] (20.0 dBm) (no IR)
            * 5260 MHz [52] (20.0 dBm) (no IR, radar detection)
              DFS state: usable (for 103 sec)
              DFS CAC time: 60000 ms
            * 5280 MHz [56] (20.0 dBm) (no IR, radar detection)
            * 5300 MHz [60] (20.0 dBm) (no IR, radar detection)
            * 5320 MHz [64] (20.0 dBm) (no IR, radar detection)
EDIT 2:
Output of iw reg get:
country GR: DFS-ETSI
    (2402 - 2482 @ 40), (N/A, 20), (N/A)
    (5170 - 5250 @ 80), (N/A, 20), (N/A)
    (5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS
    (5490 - 5710 @ 160), (N/A, 27), (0 ms), DFS
    (57000 - 66000 @ 2160), (N/A, 40), (N/A)
EDIT 3:
Output of dmesg | grep ath:
[    1.960190] ath10k_pci 0000:03:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[    2.252806] ath10k_pci 0000:03:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:03:00.0.bin failed with error -2
[    2.252815] ath10k_pci 0000:03:00.0: Direct firmware load for ath10k/cal-pci-0000:03:00.0.bin failed with error -2
[    2.269809] ath10k_pci 0000:03:00.0: qca9377 hw1.1 target 0x05020001 chip_id 0x003821ff sub 11ad:08a6
[    2.269811] ath10k_pci 0000:03:00.0: kconfig debug 0 debugfs 1 tracing 1 dfs 0 testmode 0
[    2.270128] ath10k_pci 0000:03:00.0: firmware ver WLAN.TF.1.0-00267-1 api 5 features ignore-otp crc32 79cea2c7
[    2.338522] ath10k_pci 0000:03:00.0: board_file api 2 bmi_id N/A crc32 93da0176
[    4.117342] ath10k_pci 0000:03:00.0: htt-ver 3.1 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[    4.123902] ath: EEPROM regdomain: 0x69
[    4.123903] ath: EEPROM indicates we should expect a direct regpair map
[    4.123905] ath: Country alpha2 being used: 00
[    4.123905] ath: Regpair used: 0x69
[    4.128498] ath10k_pci 0000:03:00.0 wlp3s0: renamed from wlan0
