A have a remote server for which I want to disable remote login using a password for root and other users. I have gone through a few articles on the Internet about how to do that and I have the following list of things to do/change:
  1. create private key authentication using SSH keys for all users ( I have already done this )
  2. Set the following settings in sshd_config :
    • set PermitRootLogin without-password
    • set ChallengeResponseAuthentication no
    • set PasswordAuthentication no
    • set UsePAM no
    • set AllowUsers root otheruser
  3. restart ssh using sudo service ssh reload
However, I am not sure exactly which changes are to be made to the sshd_config file and I don't want to be locked out of my remote server.
  1. If I want to be able to login as root and other users using only SSH keys, what changes do I make?
  2. If I want to prevent remote root login at all what changes do I make (and how much more secure it is as compared to remote root login using SSH keys)?
  3. If I prevent remote root login at all by making changes to sshd_config file, how will I ever be able to login as ROOT if I want to in future?
Please answer these questions as explicitly as possible and pardon me for lack of trying things as I am completely horrified of the possibility of getting locked out of my own remote server.
mxdsp
  • 3,988
user2850305
  • 163
set "UsePAM no" in sshd_config file
You don't want to turn of PAM.
  1. If I want to be able to login as root and otheruser using only SSH keys, what changes do I make?
To achieve this, these options are related:
PubkeyAuthentication yes     # missing in your list, but should be on by default)
  1. If I want to prevent remote root login at all what changes do I make (and how much more secure it is as compared to remote root login using SSH keys)?
Set PermitRootLogin no and AllowUsers otheruser.
  1. If I prevent remote root login at all by making changes to sshd_config file, how will I ever be able to login as ROOT if I want to in future?
You will log in with your non-root user and use sudo to edit the configuration files and restart sshd.
Jakuje
  • 6,793
I solved using this answer https://askubuntu.com/a/1440509/1713168
Inside the directory /etc/ssh/sshd_config.d/ there is only one .conf file (50-cloud-init.conf), but inside it contains the line: PasswordAuthentication yes
I changed the line to #PasswordAuthentication no
and i restarted the ssh. Now is working. I can only access with the ssh key.
