I know, this question has been ask several times. But Im trying to setup a ssh server.
I thought the critical setting is that I have to set PasswordAuthentication no. But I already did so and rebooted the machine. But Im still able to login with my local username and password.
Please find attached my sshd_config file
# Package generated configuration file
# See the sshd_config(5) manpage for details
# What ports, IPs and protocols we listen for
Port 22
# Use these options to restrict which interfaces/protocols sshd will bind to
#ListenAddress ::
#ListenAddress 0.0.0.0
Protocol 2
# HostKeys for protocol version 2
HostKey /etc/ssh/ssh_host_rsa_key
HostKey /etc/ssh/ssh_host_dsa_key
HostKey /etc/ssh/ssh_host_ecdsa_key
HostKey /etc/ssh/ssh_host_ed25519_key
#Privilege Separation is turned on for security
UsePrivilegeSeparation yes
# Lifetime and size of ephemeral version 1 server key
KeyRegenerationInterval 3600
ServerKeyBits 1024
# Logging
SyslogFacility AUTH
LogLevel INFO
# Authentication:
LoginGraceTime 120
PermitRootLogin without-password
StrictModes yes
RSAAuthentication yes
PubkeyAuthentication yes
AuthorizedKeysFile  %h/.ssh/authorized_keys
# Don't read the user's ~/.rhosts and ~/.shosts files
IgnoreRhosts yes
# For this to work you will also need host keys in /etc/ssh_known_hosts
RhostsRSAAuthentication no
# similar for protocol version 2
HostbasedAuthentication no
# Uncomment if you don't trust ~/.ssh/known_hosts for RhostsRSAAuthentication
#IgnoreUserKnownHosts yes
# To enable empty passwords, change to yes (NOT RECOMMENDED)
PermitEmptyPasswords no
# Change to yes to enable challenge-response passwords (beware issues with
# some PAM modules and threads)
ChallengeResponseAuthentication no
# Change to no to disable tunnelled clear text passwords
# Kerberos options
#KerberosAuthentication no
#KerberosGetAFSToken no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
# GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
X11Forwarding yes
X11DisplayOffset 10
PrintMotd no
PrintLastLog yes
TCPKeepAlive yes
#UseLogin no
#MaxStartups 10:30:60
#Banner /etc/issue.net
# Allow client to pass locale environment variables
AcceptEnv LANG LC_*
Subsystem sftp /usr/lib/openssh/sftp-server
# Set this to 'yes' to enable PAM authentication, account processing,
# and session processing. If this is enabled, PAM authentication will
# be allowed through the ChallengeResponseAuthentication and
# PasswordAuthentication.  Depending on your PAM configuration,
# PAM authentication via ChallengeResponseAuthentication may bypass
# the setting of "PermitRootLogin without-password".
# If you just want the PAM account and session checks to run without
# PAM authentication, then enable this but set PasswordAuthentication
# and ChallengeResponseAuthentication to 'no'.
UsePAM yes
bonanza
  • 121
Look at this answer, I think it's the best for you: Disabling SSH password login for Ubuntu
And I disable password login by the following configurations from that answer
# Edit the following configs of the file: /etc/ssh/sshd_config
PermitRootLogin no # Disable root login,
                   # If I want to use root,
                   # I must login as user, then sudo su
ChallengeResponseAuthentication no # Default is no
PasswordAuthentication no          # Disable password login
AllowUsers user                    # Only allow the user account login
PubkeyAuthentication yes           # Only allow the public key login
Denny
  • 111
Simply set PasswordAuthentication to "no" and "UsePAM" to "no", too. Afterwards make sure to reload sshd.
-1
You will want to edit your sshd_config file and restart the ssh server.
  • sudo vim /etc/ssh/sshd_config or gksudo gedit /etc/ssh/sshd_config
  • Set PasswordAuthentication no
  • (PermitRootLogin no is recommended)
  • sudo service ssh restart
earthmeLon
  • 11,658
