I am trying to install gpsd on a Ubuntu laptop, using sudo apt-get install gpsd. It seemed to be fine when I installed this on 2 other Ubuntu laptops. There it works properly.
Here I did the same on 3rd laptop which has Ubuntu installed. Here I received this message:
root@Lab-X230:/home/igor# sudo apt-get install gpsd
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
linux-image-extra-4.4.0-64-generic : Depends: linux-image-4.4.0-64-generic but it is not going to be installed
linux-image-extra-4.4.0-66-generic : Depends: linux-image-4.4.0-66-generic but it is not going to be installed
linux-image-extra-4.4.0-67-generic : Depends: linux-image-4.4.0-67-generic but it is not going to be installed
linux-image-generic : Depends: linux-image-4.4.0-67-generic but it is not going to be installed
linux-signed-image-4.4.0-64-generic : Depends: linux-image-4.4.0-64-generic (= 4.4.0-64.85) but it is not going to be installed
linux-signed-image-4.4.0-66-generic : Depends: linux-image-4.4.0-66-generic (= 4.4.0-66.87) but it is not going to be installed
linux-signed-image-4.4.0-67-generic : Depends: linux-image-4.4.0-67-generic (= 4.4.0-67.88) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I also tried these commands:
sudo apt-get -f install
Still it returned these error messages.
Correcting dependencies... Done
The following additional packages will be installed:
linux-image-4.4.0-64-generic linux-image-4.4.0-66-generic linux-image-4.4.0-67-generic
Suggested packages:
fdutils linux-doc-4.4.0 | linux-source-4.4.0 linux-tools
The following NEW packages will be installed:
0 upgraded, 3 newly installed, 0 to remove and 224 not upgraded.
16 not fully installed or removed.
Need to get 0 B/137 MB of archives.
After this operation, 199 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 588763 files and directories currently installed.)
Preparing to unpack .../linux-image-4.4.0-67-generic_4.4.0-67.88_amd64.deb ...
Done.
Unpacking linux-image-4.4.0-67-generic (4.4.0-67.88) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.4.0-67-generic_4.4.0-67.88_amd64.deb (--unpack):
cannot copy extracted data for './boot/System.map-4.4.0-67-generic' to '/boot/System.map-4.4.0-67-generic.dpkg-new': failed to write (No space left on device)
No apport report written because the error message indicates a disk full error
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.0-67-generic /boot/vmlinuz-4.4.0-67-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.4.0-67-generic /boot/vmlinuz-4.4.0-67-generic
Preparing to unpack .../linux-image-4.4.0-64-generic_4.4.0-64.85_amd64.deb ...
Done.
Unpacking linux-image-4.4.0-64-generic (4.4.0-64.85) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.4.0-64-generic_4.4.0-64.85_amd64.deb (--unpack):
cannot copy extracted data for './boot/vmlinuz-4.4.0-64-generic' to '/boot/vmlinuz-4.4.0-64-generic.dpkg-new': failed to write (No space left on device)
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.0-64-generic /boot/vmlinuz-4.4.0-64-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.4.0-64-generic /boot/vmlinuz-4.4.0-64-generic
Preparing to unpack .../linux-image-4.4.0-66-generic_4.4.0-66.87_amd64.deb ...
Done.
Unpacking linux-image-4.4.0-66-generic (4.4.0-66.87) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.4.0-66-generic_4.4.0-66.87_amd64.deb (--unpack):
cannot copy extracted data for './boot/vmlinuz-4.4.0-66-generic' to '/boot/vmlinuz-4.4.0-66-generic.dpkg-new': failed to write (No space left on device)
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.0-66-generic /boot/vmlinuz-4.4.0-66-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.4.0-66-generic /boot/vmlinuz-4.4.0-66-generic
From this link: sudo apt-get install steam error (because he had the same problem with me). But no one helped.
Does anyone see this problem and have any luck on this?
