17
I just installed GitKraken (A Git GUI) by downloading it from the website. When I try to install it via 'Discover Center', it doesn't work. So I found somewhere online the command dpkg -i [filename], used it on the gitkraken .deb, andddd MAGIC! It works!
I then tried to run GitKraken (by typing in gitkraken in the terminal), and that gave me this beautiful error:
Node started time: 1489531028950
libcurl.so.4: cannot open shared object file: No such file or directory
Error: libcurl.so.4: cannot open shared object file: No such file or directory
    at Error (native)
    at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:158:20)
    at Object.Module._extensions..node (module.js:568:18)
    at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:169:18)
    at Module.load (module.js:456:32)
    at tryModuleLoad (module.js:415:12)
    at Function.Module._load (module.js:407:3)
    at Module.require (module.js:466:17)
    at require (internal/module.js:20:19)
    at Object.<anonymous> (/usr/share/gitkraken/resources/app.asar/node_modules/nodegit/dist/nodegit.js:11:12)
    at Module._compile (module.js:541:32)
    at Object.Module._extensions..js (module.js:550:10)
    at Object.<anonymous> (/usr/share/gitkraken/resources/app.asar/src/appBootstrap/upgradeScripts/versionScripts/v1_5_0.js:7:17)
    at Object.<anonymous> (/usr/share/gitkraken/resources/app.asar/src/appBootstrap/upgradeScripts/versionScripts/index.js:5:28)
    at Object.<anonymous> (/usr/share/gitkraken/resources/app.asar/src/appBootstrap/upgradeScripts/index.js:7:24)
    at EventEmitter.module.exports.app.on (/usr/share/gitkraken/resources/app.asar/src/appBootstrap/main.js:146:5)
    at emitOne (events.js:101:20)
    at EventEmitter.emit (events.js:188:7)
Any help would be GREATLY appreciated.
In terminal...
  • sudo apt-get update
  • sudo apt-get install curl libcurl3
Now your app should work.
heynnema
  • 73,649
I installed libgnome-keyring-common and libgnome-keyring-dev on ubuntu 16.04 which solved it for me:
sudo apt install libgnome-keyring-common libgnome-keyring-dev
mit
  • 2,141
I used the following command:
$ sudo apt-get install curl libcurl3
and got the error below:
Reading package lists... Done
Building dependency tree
 curl : Depends: libcurl4 (= 7.58.0-2ubuntu3.8) but it is not going to be installed
So I changed my command to:
$ sudo apt-get install curl libcurl4
And always remember to update packages before, as shown by Heynnema!
