14
I am attempting to filter every notification through espeak. However, I can't seem to find a way to get the notification body from a python script, or even what signal_name to listen to.
bus.add_signal_receiver(espeak,
                    dbus_interface="org.freedesktop.Notifications",
                    signal_name="??")
Trying to google for this only seems to yield results involving creating new notifications, so I am completely lost now.
Anyone can help me with this?
In short, what I want is to listen for incoming notifications using python, and obtaining the "body" attribute of the notification.
To keep this up to date: from dbus 1.5.something an extra parameter is required when adding a match string with bus.add_match_string_non_blocking to make sure we receive everything.
The resulting code would be the following:
import glib
import dbus
from dbus.mainloop.glib import DBusGMainLoop
def notifications(bus, message):
    print [arg for arg in message.get_args_list()]
DBusGMainLoop(set_as_default=True)
bus = dbus.SessionBus()
bus.add_match_string_non_blocking("eavesdrop=true, interface='org.freedesktop.Notifications', member='Notify'")
bus.add_message_filter(notifications)
mainloop = glib.MainLoop()
mainloop.run()
joost
  • 181
By notifications you mean the "OSD bubbles" that some software sends, like changing volume, IM chat, etc? You want to create a python program to capture those?
Well, Ask Ubuntu is not a programmer's QA, and software development is a bit beyond the scope, but here is a little code I did do capture notification bubbles:
import glib
import dbus
    if message.get_member() == "Notify":
bus.add_match_string_non_blocking("interface='org.freedesktop.Notifications'")
mainloop.run()
Leave this running in a terminal, then open another terminal window and test it:
notify-send --icon=/usr/share/pixmaps/debian-logo.png "My Title" "Some text body"
And the program will output this:
[dbus.String(u'notify-send'), dbus.UInt32(0L), dbus.String(u'/usr/share/pixmaps/debian-logo.png'), dbus.String(u'My Title'), dbus.String(u'Some text body'),...
As you may have guessed, message.get_args_list()[0] is the sender, [2] for icon, [3] for summary and [4] for body text.
For the meaning of the other fields, check the official specification docs
MestreLion
  • 20,726
I had trouble getting any of the other examples to actually work but I got there in the end. Here's a working example:
import glib
import dbus
def print_notification(bus, message):
  keys = ["app_name", "replaces_id", "app_icon", "summary",
          "body", "actions", "hints", "expire_timeout"]
  args = message.get_args_list()
  if len(args) == 8:
    notification = dict([(keys[i], args[i]) for i in range(8)])
    print notification["summary"], notification["body"]
loop = DBusGMainLoop(set_as_default=True)
session_bus = dbus.SessionBus()
session_bus.add_match_string("type='method_call',interface='org.freedesktop.Notifications',member='Notify',eavesdrop=true")
session_bus.add_message_filter(print_notification)
glib.MainLoop().run()
If you want to see a more detailed working example I recommend looking at Notifications.py in the recent_notifications project.
kzar
  • 199
The above example did not work at first, so I made some small changes and now it works perfectly.
import gi
from gi.repository import GLib
import dbus
def print_notification(bus, message): keys = ["app_name", "replaces_id", "app_icon", "summary", "body", "actions", "hints", "expire_timeout"] args = message.get_args_list() if len(args) == 8: notification = dict([(keys[i], args[i]) for i in range(8)]) print(notification["summary"], notification["body"])
loop = DBusGMainLoop(set_as_default=True) session_bus = dbus.SessionBus() session_bus.add_match_string("type='method_call',interface='org.freedesktop.Notifications',member='Notify',eavesdrop=true") session_bus.add_message_filter(print_notification)
GLib.MainLoop().run()
