Is there an app/command that allows me to view recent notifications?
Preferably text-based.
I would also like to view the notification timeout for each notification. ;)
There isn't any command for retrieving previously send messages in Desktop Notifications Specification so my guess is that they are discarded after retrieving.
You can however observe these using dbus-monitor command, like this:
$ dbus-monitor "interface='org.freedesktop.Notifications'"
Sending simple notification:
$ notify-send "Hello there"
results with following information:
method call time=1555095758.597788 sender=:1.385 -> destination=:1.386 serial=6 path=/org/freedesktop/Notifications; interface=org.freedesktop.Notifications; member=GetServerInformation
method call time=1555095758.601101 sender=:1.385 -> destination=:1.386 serial=7 path=/org/freedesktop/Notifications; interface=org.freedesktop.Notifications; member=Notify
string "notify-send"
uint32 0
string ""
string "Hello there"
string ""
array [
array [
dict entry(
string "urgency"
variant byte 1
int32 -1
signal time=1555095765.734845 sender=:1.386 -> destination=:1.385 serial=15 path=/org/freedesktop/Notifications; interface=org.freedesktop.Notifications; member=NotificationClosed
uint32 1
uint32 1
Time field is an UNIX timestamp, can be translated like this:
$ date -d @1555095765
Fri Apr 12 21:02:45 CEST 2019
I've been using this for over a year on UbuntuMate 16/18
https://launchpad.net/~jconti/+archive/ubuntu/recent-notifications
If you want to do something with that data you may want some coding and not just a command line stdout, so I am using python here what you can modify to your needs. There is already a similar topic here: Listening to incoming libnotify notifications using DBus
I am copying some python code from there with some (python3) update:
import dbus
from dbus.mainloop.glib import DBusGMainLoop
def notifications(bus, message):
print(message.get_args_list())
DBusGMainLoop(set_as_default=True)
bus = dbus.SessionBus()
bus.add_match_string_non_blocking("eavesdrop=true, interface='org.freedesktop.Notifications', member='Notify'")
bus.add_message_filter(notifications)
mainloop = glib.MainLoop()
mainloop.run()
