TL;DR
I log in to a server testserver with my account testuser and I am able to perform a sudo -s because I am in the sysadm group.
When I query groups I get the sysadm group, but when I query the group directly with cat /etc/group or getent group sysadm my login is not listed in that group.
Why?
Long version
I have a user account testuser that I can use to login via putty (SSH) to a terminal session on a server (Ubuntu 14.04) called testserver.
When I run the groups command I get the following output for my account:
sysadm
Ok, so I should be in the sysadm group. I then list the sysadm group members:
getent group sysadm
...which produces the following result:
sysadm:x:800:
At this point I am slightly confused. I (testuser) am in the group and again I'm (visually) not in that group, because there are no entries at the end of the groups output.
I took a look at the sudoer configuration with visudo. I have the following configuration:
# This file MUST be edited with the 'visudo' command as root.
# Please consider adding local content in /etc/sudoers.d/ instead of
# directly modifying this file.
# See the man page for details on how to write a sudoers file.
Defaults        env_reset
Defaults        secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
# Host alias specification
# User alias specification
# Cmnd alias specification
# User privilege specification
root    ALL=(ALL:ALL) ALL
# Members of the admin group may gain root privileges
#%admin ALL=(ALL) ALL
%sysadm ALL=(ALL) ALL
# Allow members of group sudo to execute any command
#%sudo  ALL=(ALL:ALL) ALL
# See sudoers(5) for more information on "#include" directives:
#includedir /etc/sudoers.d
That's all there is in that file.
Summary
  1. I have found out that I am in the sysadm group
  2. The sysadm group does not contain any members
  3. I can sudo -s and then do whatever I want to
Questions
  1. How can I retrieve information from the system which will tell me why I am in the sysadm group?
  2. Are there any other configuration settings that will put my login in a group, that I am currently not aware of?
    a) Active Directory
    b) Policies
    c) ...
I have read the following articles so far, but none of them helped me find out why I am in the sysadm group but (visually) not in that group.
Does your entry in /etc/passwd put you in group 800 at login? getent passwd $USER | cut -d: -f4 will show you your login group. How did you (or whoever) create the testuser account?
To change your group, you will have to change /etc/passwd (man vipw), AND change the group on all the files and directories with sudo chgrp -R $NewGroup $HOME, then log out and in again.
"User" (as opposed to "System") groups usually start at 1000, but you can check in /etc/login.defs (UID_MIN).
Again, how did you (or whoever) create the testuser account?
waltinator
  • 37,856
