Trying to remove password on sudo. My current sudoers file:
Defaults        env_reset
Defaults        mail_badpass
Defaults        secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin"
root    ALL=(ALL:ALL) ALL
%admin ALL=(ALL) ALL
%sudo   ALL=(ALL:ALL) ALL
vidar ALL=(ALL) NOPASSWD: ALL
I quit, open new terminal (or even reboot), but password is still required for sudo. User is member of sudo group.
What can possibly be happening?
Vidar
  • 41
You don't have to reboot for the change to take effect.
You are missing the :ALL part of the entry.
Change from:
change to:
vidar ALL=(ALL:ALL) NOPASSWD: ALL
L. D. James
  • 25,444
The order of the entries in the sudoers file is important. You should also check the directory /etc/sudoers.d, because entries on this directory may be overwriting what you trying to do on sudoers.
You can also check the /etc/sudoers.d/README for more information.
Eduardo
  • 131
Just to elaborate on and complement the answer provided by @Eduardo , the order of the entries in the sudoers file is important not only because of possible duplicate entries, but also for group rules that a later group rule may overwrite any previous rules specified for users that belong to the group.
For example, a sudoers file like this
# User privilege specification
userX   ALL=(ALL:ALL) NOPASSWD: ALL
Members of the admin group may gain root privileges
Allow members of group sudo to execute any command
may have problems when userX belongs to either admin or sudo group, as the NOPASSWD: rule will be overwritten by rules applied to the admin and/or sudo groups, thus your NOPASSWD: rule will be lost.
So it's safer to put individual user rules in the sudoers.d directory since those will be loaded later than the default group rules.
I had similar problem. Adding my changes in /etc/sudoers.d/anotherfile made it work.
visusdo will open /etc/sudoers for editing but in my case i also added /etc/sudoers.d/anotherfile as the changes in sudoers file were not enabled.
FredyK
  • 101
