how to enable wifi in ubuntu 16.04 on dell latitude with broadcom limited bcm4313 adapter ?
sudo lshw c -network
 *-network DISABLED
       description: Wireless interface
       product: BCM4313 802.11bgn Wireless Network Adapter
       vendor: Broadcom Limited
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: wlp2s0
       version: 01
       serial: bc:85:56:a9:14:db
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=wl0 driverversion=6.30.223.248 (r487574) latency=0 multicast=yes wireless=IEEE 802.11
       resources: irq:17 memory:f7d00000-f7d03fff
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 16.10
Release:    16.10
Codename:   yakkety
lspci -knn | grep Net -A3
00:19.0 Ethernet controller [0200]: Intel Corporation 82579LM Gigabit Network Connection [8086:1502] (rev 04)
    DeviceName:  Onboard LAN
    Subsystem: Dell 82579LM Gigabit Network Connection [1028:0534]
    Kernel driver in use: e1000e
    Kernel modules: e1000e
00:1a.0 USB controller [0c03]: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2 [8086:1e2d] (rev 04)
02:00.0 Network controller [0280]: Broadcom Limited BCM4313 802.11bgn Wireless Network Adapter [14e4:4727] (rev 01)
    Subsystem: Dell BCM4313 802.11bgn Wireless Network Adapter [1028:0015]
    Kernel driver in use: wl
    Kernel modules: bcma, wl
0b:00.0 SD Host controller [0805]: O2 Micro, Inc. OZ600FJ0/OZ900FJ0/OZ600FJS SD/MMC Card Reader Controller [1217:8221] (rev 05)
rfkill list
1: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
2: brcmwl-0: Wireless LAN
    Soft blocked: no
    Hard blocked: yes
4: dell-wifi: Wireless LAN
    Soft blocked: no
    Hard blocked: yes
5: dell-bluetooth: Bluetooth
    Soft blocked: no
    Hard blocked: yes
Pilot6
  • 92,041
Your wireless adapter is hardware blocked according to your rfkill list output.
As far as I know Dell computers have a hardware switch that is off. You need to turn it on. Depending on the model it could be a Fn+some Fx key combination.
You can also check the BIOS to see if wireless is enabled there.
If you really can't find the hardware switch you can stop the dell_wmi by
sudo modprobe -r dell_wmi
Zanna
  • 72,312
Pilot6
  • 92,041
-1
Connect device with wire to modem. In GNOME open terminal sudo apt update Search on Show Applications Additional Drivers
IT Fins the proprietry Broadcom driver Enable IT.
