-1
I made this simple script where you're asked the dividend and the divisor, then it displays the quotient:
#!/bin/bash
read -p "Dividend? " dividend
read -p "Divisor? " divisor
    if [ $divisor = "0" ]
        then
            echo "∞"
    else
        echo "$((scale=4;$dividend / $divisor))" | bc
    fi
But if you type a divisor that doesn't equal to 0 this syntax error is shown:
./division.sh: line 8: scale=4;5 / 4: syntax error: invalid arithmetic operator (error token is ";5 / 4")
I don't know why this doesn't work, I saw in a thread this is the way you get decimals with bc. Anyone knows what's wrong? Thanks in advance.
Since you are using bc for the calculation, there is no need to use the bash arithmetic expansion ( $((...)) ).
Furthermore, the syntax of your arithmetic expansion is wrong as ; is no arithmetic operator. Second, this method only can output integers.
The correct script would look like as follows.
#!/bin/bash
        then
            echo "∞"
    else
        echo "scale=4;$dividend / $divisor" | bc
    fi
Thomas
  • 6,433
