118
bc handles numbers as integers:
# echo "100/3" | bc
33
bc -l handles numbers as floating point objects:
# echo "100/3" | bc -l
33.33333333333333333333
Is there a way to limit the number of digits after the decimal point?
muru
  • 207,228
Adam Matan
  • 12,919
5 Answers5
136
Set the scale special variable:
$ echo "scale=2; 100/3" | bc
33.33
chronitis
  • 12,647
25
scale works only for division; if some geeks need it in multiplication, then you can do achieve this by using string manipulation. Say if you need to multiply 32 * 0.60 , answer is 19.20. If you need to get it 19 alone in answer you can get it by different methods.
  1. Using String Manipulation
    $ S=$(echo "32*.60" | bc ) ; echo ${S%.*}
    19
    String Manipulation syntax: ${Variable%pattern}, this will delete short matching pattern that comes after %. For more String manipulation details see the Advanced Bash-Scripting Guide.
  2. Using Scale as stated by **chronitis**
    $ echo "scale=0; 32*60/100" | bc
    19
  3. To get rid of the trailing 0s, instead of string manipulation, one can also do a divide by 1.
    $ echo "0.232 * 1000" | bc
    232.000
    $ echo "0.232 * 1000 / 1" | bc
    232
SAGAR Nair
  • 1,415
you can also use printf command to round off result upto 3 decimals
# printf "%.3f\n" $(echo "100/3" | bc -l)
3.333
In addition to previous answers
echo "scale=2; 1.0150876" | bc
Returns
1.0150876
Add Math operations to get only 2 decimal numbers - (NUMBER*100)/100
echo "scale=2; (1.0150876 * 100) / 100" | bc
Now returns
1.01
Round-off
scale=2 truncates the answer to two decimal digits, but we can achieve round-off like so:
$ echo "a=12/104; scale=2; (a+0.005)/1" | bc -l
.12
spanky
  • 123
