Using Umbrello Version 2.7.4, when creating a new class, private/protected attributes are not shown in class diagram view while public are shown. I have verified that show attributes option is checked. Is this a known bug ? How it could be fixed ?
Problem seems to exists since 2.4.4: http://lists.opensuse.org/archive/opensuse/2010-12/msg00011.html
Private/protected attributes should be present with a minus/tilde sign at the start of the line.
I am running the latest Umbrello from SVN (as of 2012/01/20, r1274951) and you can right-click on your class and Uncheck Show->Public Only. You can also change this setting at the diagram properties level or in the global Umbrello settings. However, I don't know if this is available is earlier versions...
Hope this helps
Roger
  • 36
In the version I am using, 2.11, you need to right-click on your class, go to properties->display and uncheck Public Only.
Ashish
  • 101
