I have a Ubuntu 16.10 64 bit machine.
When I try to do sudo apt-get install cmake, I get the following error:
After this operation, 20.8 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 cmake amd64 3.5.2-2ubuntu1 [2,779 kB]
Err:1 http://us.archive.ubuntu.com/ubuntu yakkety/main amd64 cmake amd64 3.5.2-2ubuntu1
Hash Sum mismatch
Hashes of expected file:
- SHA256:28f7a54d94e32027321460169ddf7c66d627e96a275612e371064192b4f1fe75
- SHA1:be57190df55b20ddfc192570cd225436fa60caf0 [weak]
- MD5Sum:454e05c9e6ae224d3416b04f2a876699 [weak]
- Checksum-FileSize:2778872 [weak]
Hashes of received file:
- SHA256:d3981d14c6c2d2d0c42cc7dd00b42264e5e94f7bb2d5908ae3bbcc707e8a881b
- SHA1:9c2716a4ff17005f7a9f4c9b6cf9c370a5a813ef [weak]
- MD5Sum:9118651936fd4509d1dd98b662678ac6 [weak]
Last modification reported: Wed, 29 Jun 2016 15:10:18 +0000
Fetched 2,779 kB in 7min 48s (5,926 B/s)
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/pool/main/c/cmake/cmake_3.5.2-2ubuntu1_amd64.deb Hash Sum mismatch
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
When I run sudo apt-get update I get the following error.
#lot of lines like the next two lines
Get:30 http://us.archive.ubuntu.com/ubuntu yakkety-updates/multiverse amd64 Packages [4,653 B]
Get:32 http://us.archive.ubuntu.com/ubuntu yakkety-updates/multiverse Translation-en [2,076 B]
Fetched 816 kB in 23min 40s (574 B/s)
Reading package lists... Done
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/yakkety-updates/main/dep11/icons-64x64.tar Could not open file /var/lib/apt/lists/partial/us.archive.ubuntu.com_ubuntu_dists_yakkety-updates_main_dep11_icons-64x64.tar.gz - open (13: Permission denied) [IP: 91.189.91.26 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/yakkety-updates/universe/dep11/Components-amd64.yml.gz
E: Some index files failed to download. They have been ignored, or old ones used instead.
Can anyone kindly point me to a solution for this problem? Thanks.
