I'm downloading packages with sudo apt-mirror. What should I do next to set packages being installed from the downloaded packages? I can't even see where are the packages downloaded by default. I looked at /var/cache/apt/archives but it seems there aren't downloaded to this place.
Can I interrupt apt-mirror command and continue tommorrow where it was interrupted?
thank you
xralf
  • 75
yes, you can interrupt it ( apt-mirror ). Packages are saved on location specified in config file, /etc/apt/mirror.list. Then, to use files downloaded, you need to edit /etc/apt/sources.list ( or possibly add new file to sources.list.d directory ), i found nice how to on this blog :
http://popey.com/blog/2006/10/24/Creating_an_Ubuntu_repository_mirror_with_apt-mirror/
Denwerko
  • 1,218
Apt-mirror
sudo apt install apt-mirror
Create a Source list
sudo su
#Remove wrong ones from the configure file sed -i '17,27d' /etc/apt/mirror.list
#Insert correct ones echo " deb http://archive.ubuntu.com/ubuntu/ jammy main restricted universe multiverse deb http://archive.ubuntu.com/ubuntu/ jammy-updates main restricted universe multiverse deb http://archive.ubuntu.com/ubuntu/ jammy-security main restricted universe multiverse deb http://archive.ubuntu.com/ubuntu/ jammy-backports main restricted universe multiverse deb http://archive.canonical.com/ubuntu/ jammy partner " >> /etc/apt/mirror.list
Start Mirroring
apt-mirror
Location of packages:
/var/spool/apt-mirror/mirror/archive.ubuntu.com/ubuntu
Add to apt sources list
sudo su
echo "deb file:/var/spool/apt-mirror/mirror/archive.ubuntu.com/ubuntu jammy main restricted universe multiverse" >> /etc/apt/sources.list
sudo apt-get update
Apt-get fails with failed to fetch Packages.xz Hash Sum mismatch
apt-get hash sum mismatch
Can't install software using apt-get install : hash sum mismatch and failed to fetch errors
Trouble downloading packages list due to a "Hash sum mismatch" error
update-manager "failed to download package files" but apt upgrade works
File not found - /var/spool/apt-mirror/mirror/archive.ubuntu.com/ubuntu/dists/jammy/main/dep11/icons-64x64@2.tar (2: No such file or directory)
kubuntu 18.04 apt-get update fails with missing icon @2 files
Apt Mirror not mirroring bionic/main DEP-11 64x64@2 Icons
wget https://mirror.cs.jmu.edu/pub/ubuntu/dists/jammy-updates/universe/dep11/ -r -np
abc
  • 116
