my issue stemmed from trying to install SNMP (Install SNMP not as easy as I thought), but it failed, because my boot volume is full.(!?) Someone recommended to clean up boot, and my first attempt at following this (What is the safest way to clean up /boot partition?).... failed. Can I get a little help?
I seem to be going in the same apt-get loop as I did in my SNMP question, only this time I'm not getting DISK FULL errors, I'm getting dependency errors. So, I try to apt-get remove the listed dependency, and get more dependency errors, to the point where... I'm lost, and have almost forgotten why I'm doing this in the first place. My latest:
root@MYSERVER:/dev/mapper# uname -r
4.4.0-45-generic
root@MYSERVER:/dev/mapper# dpkg --list 'linux-image*' | grep ^ii
ii  linux-image-4.4.0-45-generic        4.4.0-45.66   amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-51-generic        4.4.0-51.72   amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-53-generic        4.4.0-53.74   amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-57-generic        4.4.0-57.78   amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-59-generic        4.4.0-59.80   amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-extra-4.4.0-45-generic  4.4.0-45.66   amd64        Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-extra-4.4.0-51-generic  4.4.0-51.72   amd64        Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-extra-4.4.0-53-generic  4.4.0-53.74   amd64        Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-extra-4.4.0-57-generic  4.4.0-57.78   amd64        Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
root@MYSERVER:/dev/mapper# sudo apt-get remove linux-image-4.4.0-57-generic
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 linux-image-extra-4.4.0-57-generic : Depends: linux-image-4.4.0-57-generic but it is not going to be installed
 linux-image-extra-4.4.0-62-generic : Depends: linux-image-4.4.0-62-generic but it is not going to be installed
 linux-image-extra-4.4.0-64-generic : Depends: linux-image-4.4.0-64-generic but it is not going to be installed
 linux-image-generic : Depends: linux-image-4.4.0-64-generic but it is not going to be installed
                       Recommends: thermald but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
root@MYSERVER:/dev/mapper# sudo apt-get remove linux-image-extra-4.4.0-57-generic
00fruX
  • 1,271
  • 17
  • 32
