Looks around for how to install SNMP. Finds multiple examples:
Just run "apt-get install snmpd".....
But when I do that I get errors. I do what it says: first run ap-get install snmpd, but it fails and tells me to try "apt-get -f install", but that fails and tells me to try "apt autoremove" but that fails and tells me to try "apt-get -f install" but that fails and.... [repeats circle of fun].
Would just like to get this Linux server (Ubuntu 16.04.1 LTS) running SNMP on public and port 161. Defaults basically.
Any ideas? I am new-ish to Linux. For all of the dependencies, do I just run commands like this?:
apt-get install linux-image-4.4.0-62-generic
apt-get install linux-image-4.4.0-64-generic
apt-get install linux-image-generic
apt-get install thermald
apt-get install libsnmp30
apt-get install libsnmp-base
etc... etc...
I am not fluent in Linux so if you have suggestions, please explain how to accomplish those suggestions.
Here is the exact loop I'm going through:
root@MYSERVER:/etc# apt-get install snmpd
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 linux-image-extra-4.4.0-62-generic : Depends: linux-image-4.4.0-62-generic but it is not going to be installed
 linux-image-extra-4.4.0-64-generic : Depends: linux-image-4.4.0-64-generic but it is not going to be installed
 linux-image-generic : Depends: linux-image-4.4.0-64-generic but it is not going to be installed
                       Recommends: thermald but it is not going to be installed
 snmpd : Depends: libsnmp30 (= 5.7.3+dfsg-1ubuntu4) but it is not going to be installed
         Depends: libsnmp-base but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
root@MYSERVER:/etc# apt-get -f install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
  linux-headers-4.4.0-51 linux-headers-4.4.0-51-generic linux-headers-4.4.0-62 linux-headers-4.4.0-62-generic linux-image-4.4.0-51-generic linux-image-4.4.0-62-generic linux-image-extra-4.4.0-51-generic
Use 'apt autoremove' to remove them.
The following additional packages will be installed:
  linux-image-4.4.0-62-generic linux-image-4.4.0-64-generic
Suggested packages:
  fdutils linux-doc-4.4.0 | linux-source-4.4.0 linux-tools
The following NEW packages will be installed:
0 upgraded, 2 newly installed, 0 to remove and 198 not upgraded.
21 not fully installed or removed.
Need to get 0 B/43.1 MB of archives.
After this operation, 131 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 346980 files and directories currently installed.)
Preparing to unpack .../linux-image-4.4.0-64-generic_4.4.0-64.85_amd64.deb ...
Done.
Unpacking linux-image-4.4.0-64-generic (4.4.0-64.85) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.4.0-64-generic_4.4.0-64.85_amd64.deb (--unpack):
 cannot copy extracted data for './boot/vmlinuz-4.4.0-64-generic' to '/boot/vmlinuz-4.4.0-64-generic.dpkg-new': failed to write (No space left on device)
No apport report written because the error message indicates a disk full error
        dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.0-64-generic /boot/vmlinuz-4.4.0-64-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.4.0-64-generic /boot/vmlinuz-4.4.0-64-generic
Preparing to unpack .../linux-image-4.4.0-62-generic_4.4.0-62.83_amd64.deb ...
Done.
Unpacking linux-image-4.4.0-62-generic (4.4.0-62.83) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.4.0-62-generic_4.4.0-62.83_amd64.deb (--unpack):
 cannot copy extracted data for './boot/vmlinuz-4.4.0-62-generic' to '/boot/vmlinuz-4.4.0-62-generic.dpkg-new': failed to write (No space left on device)
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.0-62-generic /boot/vmlinuz-4.4.0-62-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.4.0-62-generic /boot/vmlinuz-4.4.0-62-generic
root@MYSERVER:/etc#
Terrance
  • 43,712
00fruX
  • 1,271
  • 17
  • 32
