I'm trying to install cx_Oracle to use for a python script on a ubuntu vm. I first followed the first few steps listed on this site. I did originally get some overwrite errors which I got rid of by doing
sudo dpkg -i --force-overwrite (.deb file)
I had to overwrite twice, once when installing the cx_oracle .deb file and then the second time when installing the instantclient12.1-basic .deb file.
Then I tried to import cx_Oracle into python and got an ImportError. I then tried to install via pip and got the following error:
sudo -H pip install cx_oracle
Collecting cx_oracle
Using cached cx_Oracle-5.2.1.tar.gz
Building wheels for collected packages: cx-oracle
Running setup.py bdist_wheel for cx-oracle ... error
Complete output from command /usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-12y5OC/cx-oracle/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/tmpgkWhJhpip-wheel- --python-tag cp27:
running bdist_wheel
running build
running build_ext
building 'cx_Oracle' extension
creating build
creating build/temp.linux-x86_64-2.7-12c
x86_64-linux-gnu-gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/usr/include/oracle/12.1/client64 -I/usr/include/python2.7 -c cx_Oracle.c -o build/temp.linux-x86_64-2.7-12c/cx_Oracle.o -DBUILD_VERSION=5.2.1
cx_Oracle.c:6:20: fatal error: Python.h: No such file or directory
#include <Python.h>
compilation terminated.
error: command 'x86_64-linux-gnu-gcc' failed with exit status 1
Failed building wheel for cx-oracle
Running setup.py clean for cx-oracle
Failed to build cx-oracle
Installing collected packages: cx-oracle
Running setup.py install for cx-oracle ... error
Complete output from command /usr/bin/python -u -c "import setuptools, tokenize;file='/tmp/pip-build-12y5OC/cx-oracle/setup.py';f=getattr(tokenize, 'open', open)(file);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, file, 'exec'))" install --record /tmp/pip-bPwpiX-record/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_ext
creating build
#include <Python.h>
Command "/usr/bin/python -u -c "import setuptools, tokenize;file='/tmp/pip-build-12y5OC/cx-oracle/setup.py';f=getattr(tokenize, 'open', open)(file);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, file, 'exec'))" install --record /tmp/pip-bPwpiX-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-build-12y5OC/cx-oracle/
I then looked into the error and found some askubuntu links such as this which recommended that I install python-dev
Here is the result of trying to install it:
sudo apt-get install python-dev
Reading package lists... Done
Building dependency tree
python-dev : Depends: libpython-dev (= 2.7.5-5ubuntu3) but it is not going to be installed
Depends: python2.7-dev (>= 2.7.5-1~) but it is not going to be installed
I tried to follow the steps in the general unmet dependencies post and still no luck. I also tried to install the two packages that it required and was only faced with even more dependencies.
sudo apt-get install libpython-dev python2.7-dev
libpython-dev : Depends: libpython2.7-dev (>= 2.7.5-1~) but it is not going to be installed
python2.7-dev : Depends: libpython2.7-dev (= 2.7.6-8ubuntu0.3) but it is not going to be installed
Depends: libexpat1-dev but it is not going to be installed
Here is my sources list:
#This file is generated by Chef. Do not edit!
deb http://archive.ubuntu.com/ubuntu trusty main universe
deb http://archive.ubuntu.com/ubuntu trusty-updates main universe
deb http://archive.ubuntu.com/ubuntu trusty-security main universe
Am I missing any sources or is there something else that I should be doing in order to install cx_Oracle?
EDIT: I already have the oracle db client installed and so I had the following rpms installed already
oracle-instantclient12.1-devel-12.1.0.2.0-1.x86_64.rpm
oracle-instantclient12.1-basic-12.1.0.2.0-1.x86_64.rpm
oracle-instantclient12.1-sqlplus-12.1.0.2.0-1.x86_64.rpm
I then installed:
cx_Oracle-5.2.1-11g-py27-1.x86_64.rpm
