also rooted nautilus crashes at the same point. I have removed profiles of nautilus and all suspect files i have downloaded before. There is no error output in the console also no logs in /var which reffering to the crash. I saw that lot of people have the same issue but any solution fits to me. Thank you fo help
Asked
Active
Viewed 636 times
I think i found the answer
In xsession-errors log i found:
ERROR:io-xcf.c:1443:xcf_image_stop_load: code should not be reached.
it is gloobus-previewer bug which is cousing the crash. Pls look here: bugs.launchpad.net/gloobus-preview/+bug/690364. So what i did is to install gnome-xcf-thumbnailer.
I found also the suspect *.xcf.bz2 file in the /Download folder and removed it...
This is whats working for me.
Jorge Castro
- 73,717
butti
- 31
This question might be related to your problem. In particular, one answer suggests the following solution:
sudo apt-get --purge remove nautilus-open-terminal
Now, open the folder.
