Since the past few days, Nautilus has started crashing whenever I access one of the Documents, video, pictures, download folder. It does not happen when I access the home folder and other mounted drives.
The interesting thing is I do not get any error messages, Nautilus simply closes when trying to access these folders.
Can you please tell what might be the problem and how to rectify ?
I have recently installed Gnome-documents and Sushi, and am on Gnome 3.2 with Oneric 11.10.
Thanks and Regards
RobotHumans
  • 30,112
5 Answers5
Removing nautilus-open-terminal fixed it for me. None of the Ubuntu One client stuff above helped for me, but removing nautilus-open-terminal definitely did. Nautilus now opens, and it seems to open slightly quicker.
With nautilus-open-terminal installed, if I launched nautilus from terminal, I would get a number of segmentation faults, and nautilus would either not open, or it would open then close after browsing a few folders.
After reading a comment in that forum BruceBerry mentioned above, about removing nautilus-open-terminal, the terminal now can just open nautilus with absolutely no error messages and I have Ubuntu One file syncing just fine.
nLinked
  • 3,387
what i did was;
sudo apt-get purge nautilus-open-terminal
and now everything is just fine! I love the new distro!
Try to remove nautilus config files:
rm -rf ~/.nautilus
If its not working open nautilus on console, re-do it and copy the log for me pls.
fnkr
  • 5,047
I have this bug too. Apparently a fix will be released soon: https://bugs.launchpad.net/ubuntuone-client-gnome/stable-2-0/+bug/865567
In my situation, the previously mentioned solution of purging nautilus-open-terminal solved my problem, thanks to Elnetotaca
