I have a Dell Dock WD15
http://www.dell.com/en-us/shop/dell-dock-wd15-with-180w-adapter/apd/450-aeuo/pc-accessories
connected through a USB Type-C port which supports USB 3.1 & Thunderbolt 3. My computer is an Alienware 13 R3. I am running Ubuntu 16.10.
I connect my monitor through the DisplayPort on the WD15. My keyboard and mouse is connect to the USB ports on the WD15. I also use the ethernet port on the WD15 for Internet.
I usually connect the laptop to the WD15 each morning. This functions intermittently. Sometimes it works all day with no problems. Other times it fails after a few minutes.
The problem is that I lose keyboard, mouse, and network through the Dock. The video through the DisplayPort continues to function. I have to continue with the Keyboard and mouse built into the laptop.
Unplugging the WD15 from the USB Type-C port usually does not fix the problem. Most of the time a reboot fixes the problem but not always. Sometimes I have to reboot a few times. But the problem can come back in a few minutes or 30 minutes later or sometimes I don't have a problem all day.
I dual boot with Windows 10. I have the same problem with Windows10. But I don't use Windows much and I have not installed the latest Thunderbolt 3 drivers from Dell for my computer. I did a fresh install of Windows 10 and so I far just use the default drivers.
It's possible my problem is a hardware one and I have a defective Thunderbolt port (I got this computer recently). But I would like to try and diagnosis the problem. My skills with debugging hardware are not strong. I would like to know how I can try and discover what the problem is. For example what log files to look at. I have looked at dmesg and it appears to show something about a USB dock failing but that's as far as I have gone.
Can you explain what my problem might be and/or how I can diagnosis the problem?
