I am using Ubuntu 14.04 but I guess this thing can be seen in almost all versions of Ubuntu.
When I copy a file from nautilus using Ctrlc and paste into gedit it pastes the text like /home/urvish/.bash_history which is perfect for me. But when I paste it in terminal using CtrlShiftv it goes like file:///home/urvish/.bash_history.
Is there any way I can remove that preceding file:// while pasting? (I know I can do it manually but I do it very frequently and always doing manually is time taking).
muru
  • 207,228
urvish
What gnome-terminal does
From reading through Gtk documentation, it appears that there are 2 ways a program can treat contents of clipboard - plain text and list of URIs to file. For whatever reason, gnome-terminal decided that it will be good idea to differentiate between two, and therefore it when you copy a file from Nautilus to gnome-terminal, the terminal retrieves the URI list, while other programs - only plain text.
Automatic editing of clipboard would be slightly troublesome ( although I'm still pursuing the idea) - we'd need to define a way of detecting where you're trying to paste the clipboard contents, and running persistent script that edits script into plain text ( effectively deleting the URIs ) will prevent you from copying files from one Nautilus window to another.
Dragging-and-dropping is probably the simplest solution. But since a scripting approach has been requested,I came up with idea for two manual approaches. One relies on the Nautilus' built in feature of adding scripts to your right-click menu. The other on entering a specific shortcut before pasting into gnome-terminal.
Manual script approach, version 1
This script is to be placed into ~/.local/share/nautilus/scripts folder and made executable via chmod +x ~/.local/share/nautilus/scripts/scriptname.sh or via right clicking on file and editing Permissions tab in properties. Effectively, it allows you to copy path to selected files as quoted strings and with file:// portion removed.
To use it, select file or files in Nautilus, and right click them. Select Scripts menu -> your_script_name.py.
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
from gi.repository import Gtk, Gdk
import sys
import os
import time
import subprocess
import signal
import urllib.parse
import threading
def autoquit(*args):
    subprocess.call(['zenity','--info'])
    time.sleep(1)
    Gtk.main_quit()
def main():
    uris = os.getenv("NAUTILUS_SCRIPT_SELECTED_URIS")
    new_text = " ".join([ "'" + urllib.parse.unquote(i).replace('file://','') + "'"
                          for i in uris.split()])
    clip = Gtk.Clipboard.get(Gdk.SELECTION_CLIPBOARD)
    if clip.set_text(new_text,-1):
        thread = threading.Thread(target=autoquit)
        thread.start()
    Gtk.main()
if __name__ == '__main__':
    try:
        main()
    except Exception as e:
        subprocess.call(['zenity','--info','--text',str(e)])
Manual script approach, version 2
This approach relies on the idea of running the python script below right before you paste into gnome-terminal. You can call it from gnome-terminal manually as command , or bind this to a keyboard shortcut. Thus, with shortcut method, I would bind it to CtrlShiftB (because it's B and V are close on keyboard), and each time I need to paste from Nautilus, I'd hit CtrlShiftB to edit , then CtrlShiftV to paste
import subprocess
import urllib.parse
import signal
import sys
def unquote_uri(*args):
    uris = args[-2]
    new_text = " ".join([ "'" + str(urllib.parse.unquote(i).replace('file://','')) + "'"
                          for i in uris])
    print(new_text)
    args[-3].clear()
    args[-3].set_text(new_text,-1)
    Gtk.main_quit()
def main():
    cached = str()
    clip.request_uris(unquote_uri, None)
    signal.signal(signal.SIGINT,signal.SIG_DFL)
    Gtk.main()
if __name__ == '__main__': main()
Disclaimer: answer still under development; additional content/ideas may be added later
I'm a little late to the party, but I'm seeing this issue on Linux Mint MATE (mate-terminal).
It seems that simply grabbing the contents of the clipboard and then passing it back to the clipboard again will suffice. If this is the case, then we need only concerns ourselves with testing if the clipboard contents comprises one or more valid file paths, and leaving the rest unmolested.
The following will drop the file:// prefix on Mint:
import os
import pyperclip
import time
class ClipboardWatcher():
    def __init__(self,latency):
        self.clipboard_last = pyperclip.paste()
        self.clipboard_now = None
        self.latency = latency
    def check_clipboard(self):
        # assume clipboard is space delimited list of valid paths
        as_list = self.clipboard_now.split()
        valid_path = [ i for i in as_list if os.path.exists(i) ]
        if len(as_list) == len(valid_path): # assumption true
            self.clipboard_now = " ".join(valid_path)
            return True
        return False
    def run(self):
        while True:
            time.sleep(self.latency)
            self.clipboard_now = pyperclip.paste()
            if self.clipboard_now != self.clipboard_last:
                if self.check_clipboard():
                    pyperclip.copy(self.clipboard_now)
                    print "Matched:", self.clipboard_now
            self.clipboard_last = self.clipboard_now
clippy = ClipboardWatcher(1)  # watch every n seconds
clippy.run()
If you were going to implement this sort of approach then you would probably also want to daemonize it. The pyperclip module can be had with:
sudo pip install pyperclip
faustus
  • 101
