I am trying to rename some virtio ethernet devices on an Ubuntu 16.04 VM. I've done this successfully many times on non-Ubuntu systems with physical interfaces and older Ubuntu systems. Yet, despite following the advice from Renaming network interface in Ubuntu 16.04 with systemd fails and seeing Persistent network interface naming and kvm it still is not being renamed. This is on an openstack VM, but that really shouldn't matter very much.
I have tried using udev (my normal approach):
SUBSYSTEM=="net", ACTION=="add", ATTR{address}=="fa:16:3e:bf:be:d0", NAME="enet"
SUBSYSTEM=="net", ACTION=="add", ATTR{address}=="fa:16:3e:64:fb:74", NAME="snet"
I have tried using systemd.link files (with and without 99-default.link being symlinked to /dev/null):
[Match]
MACAddress=fa:16:3e:bf:be:d0
[Link]
Name=enet
and
[Match]
MACAddress=fa:16:3e:64:fb:74
[Link]
Name=snet
I have tried with both udev and systemd links. I have certainly run sudo update-initramfs -u
Both systemd and udev acknowledge the new name to some extent
systemctl says:
sys-devices-pci0000:00-0000:00:03.0-virtio0-net-ens3.device loaded active plugged Virtio network device
sys-devices-pci0000:00-0000:00:03.0-virtio0-net-enet.device loaded active plugged Virtio network device
sys-devices-pci0000:00-0000:00:04.0-virtio1-net-ens4.device loaded active plugged Virtio network device
sys-devices-pci0000:00-0000:00:04.0-virtio1-net-snet.device loaded active plugged Virtio network device
udevadm info /sys/class/net/ens3
P: /devices/pci0000:00/0000:00:03.0/virtio0/net/ens3
E: DEVPATH=/devices/pci0000:00/0000:00:03.0/virtio0/net/ens3
E: ID_BUS=pci
E: ID_MODEL_FROM_DATABASE=Virtio network device
E: ID_MODEL_ID=0x1000
E: ID_NET_DRIVER=virtio_net
E: ID_NET_LINK_FILE=/etc/systemd/network/80-etr-net-names.link
E: ID_NET_NAME_MAC=enxfa163ebfbed0
E: ID_NET_NAME_PATH=enp0s3
E: ID_NET_NAME_SLOT=ens3
E: ID_PATH=virtio-pci-0000:00:03.0
E: ID_PATH_TAG=virtio-pci-0000_00_03_0
E: ID_PCI_CLASS_FROM_DATABASE=Network controller
E: ID_PCI_SUBCLASS_FROM_DATABASE=Ethernet controller
E: ID_VENDOR_FROM_DATABASE=Red Hat, Inc
E: ID_VENDOR_ID=0x1af4
E: IFINDEX=2
E: INTERFACE=ens3
E: SUBSYSTEM=net
E: SYSTEMD_ALIAS=/sys/subsystem/net/devices/enet /sys/subsystem/net/devices/ens3
E: TAGS=:systemd:
E: USEC_INITIALIZED=1532927
But somehow, the device maintains the ensX name. I am not running NetworkManager
2: ens3: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether fa:16:3e:bf:be:d0 brd ff:ff:ff:ff:ff:ff
3: ens4: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether fa:16:3e:64:fb:74 brd ff:ff:ff:ff:ff:ff
