14
I'm using a headless Ubuntu 16.04 LTS Server with two physical network cards, which are named enp5s0f0 and enp5s0f1.
I would like to rename these interfaces, and followed this example. I therefore created the file /lib/systemd/network/70-myinterface.link (the original source does not seem to work) like this (I set the correct mac address):
[Match]
MACAddress=12:34:56:78:9a:bc
[Link]
Name=dmz0
and rebooted the server. Unfortunately the interface did not get renamed, even though udevadm shows that my configuration file is used:
$ udevadm info /sys/class/net/enp5s0f1
P: /devices/pci0000:00/0000:00:02.0/0000:01:00.0/0000:02:02.0/0000:05:00.1/net/enp5s0f1
E: DEVPATH=/devices/pci0000:00/0000:00:02.0/0000:01:00.0/0000:02:02.0/0000:05:00.1/net/enp5s0f1
E: ID_BUS=pci
E: ID_MODEL_FROM_DATABASE=80003ES2LAN Gigabit Ethernet Controller (Copper)
E: ID_MODEL_ID=0x1096
E: ID_NET_DRIVER=e1000e
E: ID_NET_LINK_FILE=/lib/systemd/network/70-myinterface.link  <-- my file
E: ID_NET_NAME_MAC=enx123456789abc
E: ID_NET_NAME_PATH=enp5s0f1
E: ID_OUI_FROM_DATABASE=Intel Corporation
E: ID_PATH=pci-0000:05:00.1
E: ID_PATH_TAG=pci-0000_05_00_1
E: ID_PCI_CLASS_FROM_DATABASE=Network controller
E: ID_PCI_SUBCLASS_FROM_DATABASE=Ethernet controller
E: ID_VENDOR_FROM_DATABASE=Intel Corporation
E: ID_VENDOR_ID=0x8086
E: IFINDEX=3
E: INTERFACE=enp5s0f1
E: SUBSYSTEM=net
E: SYSTEMD_ALIAS=/sys/subsystem/net/devices/enp5s0f1
E: TAGS=:systemd:
E: USEC_INITIALIZED=1900192
Do you have any idea why the renaming did not work?
muffel
  • 251
5 Answers5
This may or may not help .. I would check /etc/udev/rules.d and see if you have 70-persistent-net.rules. You should be able to rename them using that file
Mine looks like this:
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="e0:cb:ee:d7:ff:9a", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
If you have the entries for your cards in this file you can change the name to what ever you want by changing the "NAME=TheNameYouWant"
John Orion
  • 2,871
An option that doesn't require udev rules (an alternative to systemd-networkd .link files) that works with Ubuntu 16.04 as well as many other Linux versions is
Example:
ifconfig peth0 down
ip link set peth0 name eth0
ifconfig eth0 up
In the example above peth0 is the original interface name and eth0 is the desired name. Plug in the name you currently have where peth0 is and the name you want where eth0 is. No reboot is required or suggested. Repeat the process for the second interface card
Tested on Ubuntu 16.04 with kernel 4.4.0-36-generic #55-Ubuntu
Edit: If you are looking for a persistent solution that survives reboot see Changing Network Interfaces name Ubuntu 16.04
Sources: https://www.freedesktop.org/software/systemd/man/systemd.link.html
http://kernelpanik.net/rename-a-linux-network-interface-without-udev/
Testing.
Note: since @antti-haapala method worked before and suddenly stopped you might be interested to know that "As a special case, an empty file (file size 0) or symlink with the same name pointing to /dev/null disables the configuration file entirely (it is "masked")". <-Source
Elder Geek
  • 36,752
  • All the three custom naming methods, explained systemd: Predictable Network Interface Names, are related to udev rules.
    systemd .link's & udev rules have folder priority. /etc overrides /run overrides /lib.
    So check the current setup.
    # links
    ls -l /*/systemd/network/
    # rule that read links
    ls -l /*/udev/rules.d/80-net-setup-link.rules
    # rule that check for /etc/.../80-net-setup-link.rules & net.ifnames
    ls -l /*/udev/rules.d/73-usb-net-by-mac.rules
    After any change in these udev rules (adding/removing override files) to be effective, The boot RAM disk should be updated:
    sudo update-initramfs -u
    By default, these are the only files you may find
    ~$ ls -l /*/systemd/network/
    /etc/systemd/network/:
    total 0
    /lib/systemd/network/:
    total 12
    -rw-r--r-- 1 root root 404 Jul 12 17:28 80-container-host0.network ##(virtual-interface)
    -rw-r--r-- 1 root root 482 Jul 12 17:28 80-container-ve.network ##(virtual-interface)
    -rw-r--r-- 1 root root  80 Jul 12 17:28 99-default.link
    ~$ ls -l /*/udev/rules.d/80-net-setup-link.rules
    -rw-r--r-- 1 root root 292 Jul 12 17:28 /lib/udev/rules.d/80-net-setup-link.rules
    ~$ ls -l /*/udev/rules.d/73-usb-net-by-mac.rules
    -rw-r--r-- 1 root root 551 Jul 12 16:37 /lib/udev/rules.d/73-usb-net-by-mac.rules
    I have tested all of them in VBox fresh 16.04 install as documented in below link, all methods works as expected:
    Ubuntu 16.04 Complicated Interface Names
  • /etc/udev/rules.d/70-persistent-net-rules is from older releases replaced by systemd .link's (but they are not auto created), I added it here to check its existence for specific problems but not for AnttiHaapala's case.
user.dz
  • 49,176
I don't have enough reputation to comment, but just to add to the marked answer, clean installations of Ubuntu 16.04 won't have the /etc/udev/rules.d/70-persistent-net.rules file present. However, if you create it manually, you can add a line as shown in the answer here and it should work just like it did in older versions, with one notable difference - the KERNEL parameter should be specified as the name that was assigned to the interface by default. For example, if the system named the interface as "ens160" and you want to change it to "eth0", the line might look like:
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="xx:xx:xx:xx:xx:xx", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="ens160", NAME="eth0"
This tells the rule to only match on an interface matching the MAC specified (in the ATTR{address} parameter) and with a kernel name matching the KERNEL parameter. Alternatively you could probably omit the KERNEL parameter altogether and that should work as well.
EDIT: And as already mentioned, if you want to use the .link file method then you will need to update initramfs for it to take effect. Also note the custom .link file should be created in /etc/systemd/network and not in /lib/systemd/network (either will work but best practice is to use /etc/systemd/network since that's what its there for - to allow for custom .link files that override the defaults in /lib/systemd/network).
dwillis77
  • 111
You need to update your initrd with something like update-initramfs -k all -c, since udev applies those configs already while running initrd.
Ubuntu 16.04 doesn't have 70-persistent-net-rules file anymore.
Hizqeel
  • 1,915
  • 28
  • 24
  • 24
