How can I run a shell script in background?
Depending on what you are wanting, just add a & to the end of the command
script.sh &
command &
If you are running it in a terminal, and you want to then close the terminal, use nohup or disown
nohup
nohup script.sh &
disown
script &
disown
If that is not what you are after, please be more specific in your question.
- 104,528
If you want the script to remain after closing the terminal, another option is to use setsid:
setsid script.sh
For more information about the differences between nohup, disown, & and setsid: Difference between nohup, disown and &
- 386
you can just switch screen and run your script on that 2nd screen. When script started on 2nd, switch back to 1st and do whatever you want. 2nd screen will be in the background as extra "terminal window". and it will not stop processing even when you close your ssh connection while beeing at 1st screen.
screen --help
Use: screen [-opts] [cmd [args]]
or: screen -r [host.tty]
Options:
-4 Resolve hostnames only to IPv4 addresses.
-6 Resolve hostnames only to IPv6 addresses.
-a Force all capabilities into each window's termcap.
-A -[r|R] Adapt all windows to the new display width & height.
-c file Read configuration file instead of '.screenrc'.
-d (-r) Detach the elsewhere running screen (and reattach here).
-dmS name Start as daemon: Screen session in detached mode.
-D (-r) Detach and logout remote (and reattach here).
-D -RR Do whatever is needed to get a screen session.
-e xy Change command characters.
-f Flow control on, -fn = off, -fa = auto.
-h lines Set the size of the scrollback history buffer.
-i Interrupt output sooner when flow control is on.
-l Login mode on (update /var/run/utmp), -ln = off.
-ls [match] or -list. Do nothing, just list our SockDir [on possible matches].
-L Turn on output logging.
-m ignore $STY variable, do create a new screen session.
-O Choose optimal output rather than exact vt100 emulation.
-p window Preselect the named window if it exists.
-q Quiet startup. Exits with non-zero return code if unsuccessful.
-r [session] Reattach to a detached screen process.
-R Reattach if possible, otherwise start a new session.
-s shell Shell to execute rather than $SHELL.
-S sockname Name this session <pid>.sockname instead of <pid>.<tty>.<host>.
-t title Set title. (window's name).
-T term Use term as $TERM for windows, rather than "screen".
-U Tell screen to use UTF-8 encoding.
-v Print "Screen version 4.01.00devel (GNU) 2-May-06".
-wipe [match] Do nothing, just clean up SockDir [on possible matches].
-x Attach to a not detached screen. (Multi display mode).
-X Execute <cmd> as a screen command in the specified session.
ctrl+a, c will create a new "window" in your active screen session. You can switch between multiple windows (as Ansgar indicated) with ctrl+a, n for the next window, and ctrl+a,p for the previous window.
ctrl+a," will give you a list of all your open windows.
More: https://superuser.com/questions/476709/quickly-switching-between-virtual-sessions-screen
- 279
If your process is already running you can put its execution to background.
ctrl+z will stop the process, and bg will continue process in background
- 21
tmux is also a choice.
tmux./script.sh- PREFIX + d
will detach it.
tmux a -t <number>
will recover session.
- 259
In case you want to keep the log of the command and view with tail with process detached form shell:
TEMP_LOG_FILE=/home/user_name/my_log.log > "$TEMP_LOG_FILE"
for command
nohup ./process &> "$TEMP_LOG_FILE" & tail -f "$TEMP_LOG_FILE" &
for script
nohup /process.sh &> "$TEMP_LOG_FILE" & tail -f "$TEMP_LOG_FILE" &
- 432
