I am a Windows user trying to adapt to Linux. Currently, I am running Ubuntu 16.04.
Recently I changed my wireless card from a Realtek RT3290 with severe connection problems under Ubuntu and Mint for a Qualcomm QCA9565 also known as DELL 1705.
The problem is: I don't have bluetooth with neither card. Previously, with RT3290, the blutooth module coudn't load but I did see something bt related under "rfkill list". Now, I don't see anything at all! This module was installed on a Dell Laptop with Windows and the bluetooth part worked just fine.
Here's some information:
angourakis@angourakis-nb ~ $ lsusb
Bus 001 Device 002: ID 8087:8000 Intel Corp.
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 003: ID 04f3:0280 Elan Microelectronics Corp.
Bus 002 Device 002: ID 0bda:5775 Realtek Semiconductor Corp. HP "Truevision HD" laptop camera
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
angourakis@angourakis-nb ~ $ uname -a
Linux angourakis-nb 4.4.0-59-generic #80-Ubuntu SMP Fri Jan 6 17:47:47 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
angourakis@angourakis-nb ~ $ ls -l /sys/class/bluetooth
ls: cannot access '/sys/class/bluetooth': No such file or directory
angourakis@angourakis-nb ~ $ lsmod | grep bt
btrfs 987136 0
xor 24576 1 btrfs
raid6_pq 102400 1 btrfs
angourakis@angourakis-nb ~ $ rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
angourakis@angourakis-nb ~ $ lspci -nnk | grep 0280 -A2
08:00.0 Network controller [0280]: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter [168c:0036] (rev 01)
Subsystem: Dell QCA9565 / AR9565 Wireless Network Adapter [1028:020c]
Kernel driver in use: ath9k
angourakis@angourakis-nb ~ $ sudo modprobe ath9k && dmesg | grep ath
[ 3.836205] ath: phy0: WB335 1-ANT card detected
[ 3.836209] ath: phy0: Set BT/WLAN RX diversity capability
[ 3.845203] ath: phy0: Enable LNA combining
[ 3.846545] ath: phy0: ASPM enabled: 0x43
[ 3.846548] ath: EEPROM regdomain: 0x60
[ 3.846548] ath: EEPROM indicates we should expect a direct regpair map
[ 3.846550] ath: Country alpha2 being used: 00
[ 3.846551] ath: Regpair used: 0x60
[ 4.014927] ath9k 0000:08:00.0 wlp8s0: renamed from wlan0
[ 10.366513] ath: EEPROM regdomain: 0x807c
[ 10.366516] ath: EEPROM indicates we should expect a country code
[ 10.366517] ath: doing EEPROM country->regdmn map search
[ 10.366518] ath: country maps to regdmn code: 0x3a
[ 10.366520] ath: Country alpha2 being used: CA
[ 10.366520] ath: Regpair used: 0x3a
[ 10.366522] ath: regdomain 0x807c dynamically updated by country IE
[ 730.476683] ath: EEPROM regdomain: 0x807c
[ 730.476686] ath: EEPROM indicates we should expect a country code
[ 730.476686] ath: doing EEPROM country->regdmn map search
[ 730.476687] ath: country maps to regdmn code: 0x3a
[ 730.476688] ath: Country alpha2 being used: CA
[ 730.476689] ath: Regpair used: 0x3a
[ 730.476690] ath: regdomain 0x807c dynamically updated by country IE
Do you have any suggestions? The strange thing is that I also tried installing Windows 10, but it didn't recognize my bluetooth either.
