Whenever I switch my old Dell E520 on first thing in the morning it fails to boot into Ubuntu 16.04. It gets through bios to grub & beyond but will stop while trying to load the os. It finishes at a black screen. This seems a common problem & I've tried all the suggested solutions appropriate to my setup from the My computer boots to a black screen, what options do I have to fix it? thread, but none have worked for me.
What seems different from any other solution or discussion offered is that I have found a strange workaround: if I get to grub & run memtest for a minute then press esc to reboot, all is well! This works every time.
My questions are: Can anyone suggest why this works? Is there a solution that does not need my intervention at grub?
zhdeef
Add nomodeset to your grub commandline.
Edit your /etc/default/grub file.
Look for this line:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Append nomodeset to the line so it looks like this:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nomodeset"
Now update your grub with:
$ sudo update-grub
Then reboot.
L. D. James
  • 25,444
This is a thermal problem, but it's reversed from the usual heat issues. One of the connections in your system RAM slots is only making contact when the system has warmed up a bit -- as it'll do after one or more boot failures, or after running memtest for a short time. Try removing and reseating your RAM modules, and you'll probably find the wiping action of the contacts brings back reliable connection and resolves the problem.
Zeiss Ikon
  • 5,248
