An annoying problem I have is that upower will take a few minutes or more to update my battery status (This problem is similar to this post but I provide my laptop's details). That means if I wake my laptop from hibernation it shows the wrong battery percentage for a few minutes, and when I plug in my charger the battery icon does not indicate so (though the hardware charge light turns on). Other than those cases I don't mind the update time.
Curiously, when I unplug my charger, the icon updates immediately. I've come up with a temporary solution to update on wake that may or may not work but it seems to be there should be a good fix. Running Ubuntu 16.04 on Acer Aspire E5-575G-53VG.
acpi always shows the correct battery percentage and status. sudo service upower restart forces the battery status of upower to update.
Output of upower --monitor-detail when plugging in charger:
Monitoring activity from the power daemon. Press Ctrl+C to cancel.
[00:55:46.411] device changed: /org/freedesktop/UPower/devices/battery_BAT1
native-path: BAT1
vendor: PANASONIC
model: AS16B5J
serial: 2217
power supply: yes
updated: Wed 01 Feb 2017 12:55:46 AM EST (0 seconds ago)
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
warning-level: none
energy: 50.9157 Wh
energy-empty: 0 Wh
energy-full: 55.6554 Wh
energy-full-design: 62.16 Wh
energy-rate: 6.6933 W
voltage: 12.562 V
time to empty: 7.6 hours
percentage: 91%
capacity: 89.5357%
technology: lithium-ion
icon-name: 'battery-full-symbolic'
History (rate):
1485928546 6.693 discharging
1485928537 10.856 discharging
1485928517 6.083 discharging
1485928504 10.423 discharging
1485928485 6.149 discharging
1485928466 21.190 discharging
1485928463 6.371 discharging
1485928449 7.071 discharging
[00:55:46.414] device changed: /org/freedesktop/UPower/devices/battery_BAT1
native-path: BAT1
vendor: PANASONIC
model: AS16B5J
serial: 2217
power supply: yes
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
warning-level: none
energy: 50.9157 Wh
energy-empty: 0 Wh
voltage: 12.562 V
percentage: 91%
capacity: 89.5357%
History (rate):
[00:55:46.417] device changed: /org/freedesktop/UPower/devices/battery_BAT1
native-path: BAT1
vendor: PANASONIC
model: AS16B5J
serial: 2217
power supply: yes
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
warning-level: none
energy: 50.9157 Wh
energy-empty: 0 Wh
voltage: 12.562 V
percentage: 91%
capacity: 89.5357%
History (rate):
[00:55:46.419] device changed: /org/freedesktop/UPower/devices/battery_BAT1
native-path: BAT1
vendor: PANASONIC
model: AS16B5J
serial: 2217
power supply: yes
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
warning-level: none
energy: 50.9157 Wh
energy-empty: 0 Wh
voltage: 12.562 V
percentage: 91%
capacity: 89.5357%
History (rate):
[00:55:46.422] device changed: /org/freedesktop/UPower/devices/line_power_ACAD
native-path: ACAD
power supply: yes
has history: no
has statistics: no
line-power
warning-level: none
online: yes
icon-name: 'ac-adapter-symbolic'
native-path: ACAD
power supply: yes
has history: no
has statistics: no
line-power
warning-level: none
online: yes
[00:55:46.422] daemon changed:
daemon-version: 0.99.4
on-battery: no
lid-is-closed: no
lid-is-present: yes
critical-action: HybridSleep
Output when I unplug charger:
[00:58:17.752] device changed: /org/freedesktop/UPower/devices/battery_BAT1
native-path: BAT1
vendor: PANASONIC
model: AS16B5J
serial: 2217
power supply: yes
updated: Wed 01 Feb 2017 12:58:17 AM EST (0 seconds ago)
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
warning-level: none
energy: 50.838 Wh
energy-empty: 0 Wh
energy-rate: 10.8669 W
voltage: 12.656 V
time to empty: 4.7 hours
percentage: 91%
capacity: 89.5357%
History (charge):
1485928697 91.000 discharging
1485928672 0.000 unknown
History (rate):
1485928697 10.867 discharging
[00:58:17.765] device changed: /org/freedesktop/UPower/devices/battery_BAT1
native-path: BAT1
vendor: PANASONIC
model: AS16B5J
serial: 2217
power supply: yes
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
warning-level: none
energy: 50.838 Wh
energy-empty: 0 Wh
voltage: 12.656 V
percentage: 91%
capacity: 89.5357%
History (charge):
History (rate):
[00:58:17.773] device changed: /org/freedesktop/UPower/devices/battery_BAT1
native-path: BAT1
vendor: PANASONIC
model: AS16B5J
serial: 2217
power supply: yes
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
warning-level: none
energy: 50.838 Wh
energy-empty: 0 Wh
voltage: 12.656 V
percentage: 91%
capacity: 89.5357%
History (charge):
History (rate):
[00:58:17.781] device changed: /org/freedesktop/UPower/devices/battery_BAT1
native-path: BAT1
vendor: PANASONIC
model: AS16B5J
serial: 2217
power supply: yes
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
warning-level: none
energy: 50.838 Wh
energy-empty: 0 Wh
voltage: 12.656 V
percentage: 91%
capacity: 89.5357%
History (charge):
History (rate):
[00:58:17.789] device changed: /org/freedesktop/UPower/devices/battery_BAT1
native-path: BAT1
vendor: PANASONIC
model: AS16B5J
serial: 2217
power supply: yes
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
warning-level: none
energy: 50.838 Wh
energy-empty: 0 Wh
voltage: 12.656 V
percentage: 91%
capacity: 89.5357%
History (charge):
History (rate):
[00:58:17.797] device changed: /org/freedesktop/UPower/devices/battery_BAT1
native-path: BAT1
vendor: PANASONIC
model: AS16B5J
serial: 2217
power supply: yes
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
warning-level: none
energy: 50.838 Wh
energy-empty: 0 Wh
voltage: 12.656 V
percentage: 91%
capacity: 89.5357%
History (charge):
History (rate):
[00:58:17.803] device changed: /org/freedesktop/UPower/devices/battery_BAT1
native-path: BAT1
vendor: PANASONIC
model: AS16B5J
serial: 2217
power supply: yes
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
warning-level: none
energy: 50.838 Wh
energy-empty: 0 Wh
voltage: 12.656 V
percentage: 91%
capacity: 89.5357%
History (charge):
History (rate):
[00:58:17.809] device changed: /org/freedesktop/UPower/devices/battery_BAT1
native-path: BAT1
vendor: PANASONIC
model: AS16B5J
serial: 2217
power supply: yes
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
warning-level: none
energy: 50.838 Wh
energy-empty: 0 Wh
voltage: 12.656 V
percentage: 91%
capacity: 89.5357%
History (charge):
History (rate):
[00:58:17.811] device changed: /org/freedesktop/UPower/devices/line_power_ACAD
native-path: ACAD
power supply: yes
has history: no
has statistics: no
line-power
warning-level: none
online: no
native-path: ACAD
power supply: yes
has history: no
has statistics: no
line-power
warning-level: none
online: no
[00:58:17.811] daemon changed:
on-battery: yes
lid-is-closed: no
lid-is-present: yes
What I noticed is that when the charger is plugged in, the battery state is still discharging. However, /org/freedesktop/UPower/devices/line_power_ACAD reports online correctly. Any help with this problem is appreciated. I do not recall having this issue on KDE.
