EDIT: following the instructions on this thread, I attempted to remove my old/unused kernels but could not. It looks like there's not enough space for the operation, what do I do?
Output of ls /boot/:
abi-4.2.0-42-generic         initrd.img-4.4.0-57-generic
abi-4.4.0-45-generic         lost+found
abi-4.4.0-47-generic         memtest86+.bin
abi-4.4.0-51-generic         memtest86+.elf
config-4.2.0-42-generic      memtest86+_multiboot.bin
config-4.4.0-45-generic      System.map-4.2.0-42-generic
config-4.4.0-47-generic      System.map-4.4.0-45-generic
config-4.4.0-51-generic      System.map-4.4.0-47-generic
grub                         System.map-4.4.0-51-generic
initrd.img-4.2.0-42-generic  vmlinuz-4.2.0-42-generic
initrd.img-4.4.0-42-generic  vmlinuz-4.4.0-45-generic
initrd.img-4.4.0-45-generic  vmlinuz-4.4.0-47-generic
initrd.img-4.4.0-47-generic  vmlinuz-4.4.0-51-generic
initrd.img-4.4.0-51-generic
Output of dpkg -l linux-image-\* | grep ^ii
ii  linux-image-4.2.0-42-generic       4.2.0-42.49  amd64        Linux kernel image for version 4.2.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-45-generic       4.4.0-45.66  amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-47-generic       4.4.0-47.68  amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-51-generic       4.4.0-51.72  amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-extra-4.2.0-42-generic 4.2.0-42.49  amd64        Linux kernel extra modules for version 4.2.0 on 64 bit x86 SMP
ii  linux-image-extra-4.4.0-45-generic 4.4.0-45.66  amd64        Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
However, when I run sudo apt-get purge linux-image-4.2.0-42 linux-image-4.4.0-45, I get the following messages:
gzip: stdout: No space left on device
E: mkinitramfs failure cpio 141 gzip 1
update-initramfs: failed for /boot/initrd.img-4.4.0-47-generic with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
dpkg: error processing package linux-image-extra-4.4.0-47-generic (--remove):
 subprocess installed post-removal script returned error exit status 1
Am I doing something wrong?
ORIGINAL:
I've been getting space errors whenever I try to upgrade, and on the dist-upgrade I tried just now I got the following errors:
E: mkinitramfs failure find 141 cpio 141 gzip 1
update-initramfs: failed for /boot/initrd.img-4.4.0-51-generic with 1.
dpkg: error processing package linux-image-extra-4.4.0-51-generic (--configure):
 subprocess installed post-installation script returned error exit status 1
The output of df is:
Filesystem                   1K-blocks     Used Available Use% Mounted on
udev                           1787060        0   1787060   0% /dev
tmpfs                           361572    10496    351076   3% /run
/dev/mapper/xubuntu--vg-root 236014344 38503396 185499020  18% /
tmpfs                          1807848      172   1807676   1% /dev/shm
tmpfs                             5120        4      5116   1% /run/lock
tmpfs                          1807848        0   1807848   0% /sys/fs/cgroup
/dev/sda1                       240972   227218      1313 100% /boot
tmpfs                           361572       36    361536   1% /run/user/1000
and the output of uname -r:
4.4.0-51-generic
I've tried several things based on solutions offered to some of these errors individually, but I haven't had any luck yet.
Thank you sincerely for any help!
J Clark
