I have Ubuntu 16.04 (32bit) I have openjdk version "1.8.0_121"
I am getting an error from a makefile saying:
You are attempting to build with the incorrect version
of java.
Your version is: openjdk version "1.8.0_121".
The correct version is: Java SE 1.6.
I have tried
sudo apt-get install openjdk-6-jdk
returned
openjdk-6-jdk has no installation candidate
Tried going to http://www.oracle.com/technetwork/java/javase/archive-139210.html
Wont install because of multiple errors
Unpacking...
Checksumming...
Extracting...
./jdk-6u45-linux-i586-rpm.bin: 144: ./jdk-6u45-linux-i586-rpm.bin: ./install.sfx.17173: not found
Installing JavaDB
rpm: RPM should not be used directly install RPM packages, use Alien instead!
rpm: However assuming you know what you are doing...
error: open of sun-javadb-common-10.6.2-1.1.i386.rpm failed: No such file or directory
error: open of sun-javadb-core-10.6.2-1.1.i386.rpm failed: No such file or directory
error: open of sun-javadb-client-10.6.2-1.1.i386.rpm failed: No such file or directory
error: open of sun-javadb-demo-10.6.2-1.1.i386.rpm failed: No such file or directory
error: open of sun-javadb-docs-10.6.2-1.1.i386.rpm failed: No such file or directory
error: open of sun-javadb-javadoc-10.6.2-1.1.i386.rpm failed: No such file or directory
Done.
Also tried the non rpm version from http://www.oracle.com/technetwork/java/javase/archive-139210.html and got:
Unpacking...
Checksumming...
Extracting...
./jdk-6u45-linux-i586.bin: 74: ./jdk-6u45-linux-i586.bin: ./install.sfx.17296: not found
Failed to extract the files. Please refer to the Troubleshooting section of
the Installation Instructions on the download page for more information.
Somewhere I found openjdk-6_6b38-1.13.10.orig.tar.gz forget where I got that, but it was complaining I didn't have a JDK home directory.
configure: error: "A JDK home directory could not be found."
Im just digging deeper and nothing is working. Wondering if theres some simple repo that I can get openjdk-6-jdk that will actually work?
Thanks!
