I've always had some trouble with my wifi card. I was on Ubuntu 14.04 and sometimes I had no wifi and the option "enable wifi" didn't appear until I restarted my computer.
One day, it just stopped working, nothing to do. I upgraded to Ubuntu 16.10, still it doesn't work.
After I installed bcmwl-kernel-source, the bluetooth works but not the wifi, just like before.
I've tried so many solutions, but none of them worked for me:
sudo ifconfig wlan0 up
(wlan0 doesn't exist)
service network-manager restart
(there's no problem with network-manager I guess)
apt-get purge bcmwl-kernel-source
apt-get install b43-fwcutter firware-b43-installer
(I ended up reinstalling bcmwl-kernel-source from the additional drivers tab)
sudo modprobe wl
sudo modprobe b43
(the process keeps running, but nothing happens)
Checking secure mode in Bios ; already disabled
brace yourselves
I was so desperate that I thought that my ethernet card had some secret wireless powers XD so here's what I did
sudo lspci | grep -i ethernet
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller (rev 05)
sudo modprobe -rfv wl rt2800pci
sudo apt-get purge bcmwl-kernel-source
sudo modprobe -v rt2800pci
should I undo it to fix this ? and how ? of course I ended up reinstalling bcmwl-kernel-source as I said, from Additional Drivers.
of course, the wifi is on (Fn+F2 on my Dell inspiron 15)
Here are some outputs that could be useful:
lspci
$ lspci -nn | grep Net*
02:00.0 Network controller [0280]: Broadcom Limited BCM43142 802.11b/g/n [14e4:4365] (rev 01)
$ lspci -k | grep -i network -A 2
02:00.0 Network controller: Broadcom Limited BCM43142 802.11b/g/n (rev 01)
    Subsystem: Device 1128:0016
    Kernel driver in use: wl
lsusb
$ lsusb
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 005: ID 0c45:649a Microdia
Bus 001 Device 004: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 003: ID 0a5c:21d7 Broadcom Corp. BCM43142 Bluetooth 4.0
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
ifconfig
the interface wlan0 doesn't even exist
$ sudo ifconfig
enp1s0    Link encap:Ethernet  HWaddr 74:86:7a:61:2d:19
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          Packets reçus:5723 erreurs:0 :0 overruns:0 frame:0
          TX packets:5836 errors:2 dropped:0 overruns:0 carrier:0
          collisions:0 lg file transmission:1000
          Octets reçus:3856720 (3.8 MB) Octets transmis:718950 (718.9 KB)
lo        Link encap:Boucle locale
          inet adr:127.0.0.1  Masque:255.0.0.0
          adr inet6: ::1/128 Scope:Hôte
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          Packets reçus:4302 erreurs:0 :0 overruns:0 frame:0
          TX packets:4302 errors:0 dropped:0 overruns:0 carrier:0
          Octets reçus:321187 (321.1 KB) Octets transmis:321187 (321.1 KB)
iwconfig
$ iwconfig
lo        no wireless extensions.
enp1s0    no wireless extensions.
rfkill list
as I said, only Bluetooth is working
$ rfkill list all
0: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
ls -1 /etc/modprobe.d
the bcm43 is blacklisted, is that normal ? Or should I do something ?
$ ls -1 /etc/modprobe.d/
alsa-base.conf
blacklist-ath_pci.conf
blacklist-bcm43.conf
blacklist.conf
blacklist-firewire.conf
blacklist-framebuffer.conf
blacklist-modem.conf
blacklist-oss.conf
blacklist-rare-network.conf
blacklist-watchdog.conf
dkms.conf
fbdev-blacklist.conf
intel-microcode-blacklist.conf
iwlwifi.conf
mlx4.conf
vmwgfx-fbdev.conf
dmesg
$ dmesg | grep wl
[   17.618389] wl: module license 'MIXED/Proprietary' taints kernel.
[   17.620902] wl: module verification failed: signature and/or required key missing - tainting kernel
[   17.634296] wl driver 6.30.223.248 (r487574) failed with code 1
[   17.634405] Modules linked in: wl(POE+) snd_rawmidi snd_seq dell_wmi sparse_keymap intel_rapl x86_pkg_temp_thermal intel_powerclamp coretemp mei_me snd_seq_device snd_timer kvm_intel cfg80211 kvm mei snd dell_laptop dcdbas dell_smm_hwmon irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel joydev input_leds cryptd serio_raw shpchp lpc_ich soundcore mac_hid parport_pc ppdev lp parport autofs4 rtsx_usb_sdmmc rtsx_usb i915 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops psmouse ahci drm r8169 libahci mii wmi video fjes
[   17.634930] RIP: 0010:[<ffffffffc07f3673>]  [<ffffffffc07f3673>] wl_cfg80211_detach+0xf3/0x100 [wl]
[   17.635549]  [<ffffffffc07eaf06>] ? wl_free_if.isra.15+0x26/0xa0 [wl]
[   17.635620]  [<ffffffffc07eb780>] wl_free+0x60/0x270 [wl]
[   17.635747]  [<ffffffffc07ebd3d>] wl_pci_probe+0x3ad/0x740 [wl]
[   17.642095]  [<ffffffffc03f2084>] wl_module_init+0x84/0x1000 [wl]
[   17.659643] RIP  [<ffffffffc07f3673>] wl_cfg80211_detach+0xf3/0x100 [wl]
Zanna
  • 72,312
Hadjer Ch
Your dmesg suggests a very unhappy hardware and driver combination. I suggest that you purge and reinstall the driver:
With a working internet connection:
wget http://mirrors.kernel.org/ubuntu/pool/restricted/b/bcmwl/bcmwl-kernel-source_6.30.223.248+bdcom-0ubuntu11_amd64.deb
sudo dpkg -i bcmwl*.deb
Note: This assumes that yours is a 64-bit installation; check: arch
Reboot and check again:
dmesg | grep wl
If you still see these alarming errors:
Then, based on the fact that this failed on both 14.04 and 16.10, I suspect the hardware itself. Is the card seated firmly in its connector? Are the antenna wires connected firmly? Is the card electrically defective?
We see in your pastes that the kernel bug remains. I suggest that you blacklist the driver:
sudo -i
echo "blacklist wl"  >>  /etc/modprobe.d/blacklist.conf
exit
Reboot. Now, let's try an alternate driver:
sudo modprobe brcmsmac
Any improvement? Any clues in the log?
dmesg | grep brcm
If you have tried unsuccessfully both the Broadcom proprietary driver wl as well as brcmsmac, then I suggest that you file a bug report: https://help.ubuntu.com/community/ReportingBugs
Finally, I'd invest in a USB wireless device until the bug is fixed. A search here and on ubuntuforums.org will reveal several.
chili555
  • 61,330
You have the correct driver installed, the bcmwl-kernel-source.
The problem is that it can't load because of Secure Boot option enabled in your BIOS. Disable it, and all should work.
You need to remove blacklist wl from /etc/modprobe.d/blacklist.conf if you did that already.
Pilot6
  • 92,041
