I've recently obtained the TP-Link WN822Nv4 (EU) adapter because my onboard adapter doesn't seem to work very well (low signal strength, my phone gets 10x the speeds), however I can't for the life of me figure out how to make it work. I've tried searching the site for similar things (like this and this, the second one reported an error of some kind), but none of them seem to work. My laptop is a HP Pavilion G6-2002SM if it matters.
Output of lsusb ( Device 004 is the adapter I think):
Bus 004 Device 003: ID 04f2:b2f4 Chicony Electronics Co., Ltd
Bus 004 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 004: ID 2357:0108
Bus 003 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 1bcf:0005 Sunplus Innovation Technology Inc. Optical Mouse
Version:
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=14.04
DISTRIB_CODENAME=trusty
DISTRIB_DESCRIPTION="Ubuntu 14.04.4 LTS"
uname -a:
Linux bloop 3.19.0-42-generic #48~14.04.1-Ubuntu SMP Fri Dec 18 10:24:49 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
lshw -C network:
*-network
   description: Network controller
   product: BCM4313 802.11bgn Wireless Network Adapter
   vendor: Broadcom Corporation
   physical id: 0
   bus info: pci@0000:07:00.0
   version: 01
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress bus_master cap_list
   configuration: driver=bcma-pci-bridge latency=0
   resources: irq:16 memory:c3500000-c3503fff
*-network
   description: Ethernet interface
   product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
   vendor: Realtek Semiconductor Co., Ltd.
   physical id: 0
   bus info: pci@0000:08:00.0
   logical name: eth0
   version: 05
   serial: 80:c1:6e:60:1c:38
   capacity: 100Mbit/s
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
   configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl_nic/rtl8105e-1.fw latency=0 link=no multicast=yes port=MII speed=10Mbit/s
   resources: irq:27 ioport:3000(size=256) memory:c3404000-c3404fff memory:c3400000-c3403fff
 *-network
   description: Wireless interface
   physical id: 2
   logical name: wlan0
   serial: c0:18:85:1b:0d:21
   capabilities: ethernet physical wireless
   configuration: broadcast=yes driver=brcmsmac driverversion=3.19.0-42-generic firmware=610.812 ip=10.40.101.111 link=yes multicast=yes wireless=IEEE 802.11bgn
dkms status:
8192cu, 1.10, 3.19.0-42-generic, x86_64: installed
rtl8192eu, 4.3.1.1.11320.20140505~trusty1: added
lspci:
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04)
00:16.0 Communication controller: Intel Corporation 7 Series/C210 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 1 (rev c4)
00:1c.1 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 2 (rev c4)
00:1c.2 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 3 (rev c4)
00:1d.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation HM76 Express Chipset LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 7 Series/C210 Series Chipset Family SMBus Controller (rev 04)
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Thames [Radeon HD 7500M/7600M Series] (rev ff)
07:00.0 Network controller: Broadcom Corporation BCM4313 802.11bgn Wireless Network Adapter (rev 01)
08:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller (rev 05)
09:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
I'm not too familiar with troubleshooting on Linux so I can't figure out how to solve the problem. Any advice?
blueshift
  • 103
I didn't notice the kernel version, to update to 4.4 you can
sudo apt-get install linux-generic-lts-xenial
We need to get rid of one of the dkms installs as I am not sure Pilot6 updated his PPA for Trusty
sudo dkms remove rtl8192eu/4.3.1.1.11320.20140505~trusty1 --all
sudo dkms remove 8192cu/1.10 --all
Reboot
Then we can install git and build-essential
sudo apt-get install git build-essential
Then we can clone Mange's github code
git clone https://github.com/Mange/rtl8192eu-linux-driver.git
Then use dkms to add it sudo dkms add ./rtl8192eu-linux-driver
Then install
sudo dkms install -m rtl8192eu -v 1.0
Reboot
Mange's code will support your device because of a commit made 6 months ago
+    /===TPLINK ID===========/
 +  {USB_DEVICE(0x2357, 0x0107),.driver_info = RTL8192E}, /* TP-Link - Cameo /
 +  {USB_DEVICE(0x2357, 0x0108),.driver_info = RTL8192E}, / TP-Link - Cameo /
 +  {USB_DEVICE(0x2357, 0x0109),.driver_info = RTL8192E}, / TP-Link - Cameo */
  #endif
Jeremy31
  • 13,293
