I'm setting up a LEMP stack on Google Compute Engine to run Magento 1.9. I've configured the server with PHP7/Nginx with Ubuntu 14.04. When I run the Magento setup, halfway through it redirects from downloader.php to downloader/ and I get a 403 Forbidden error.
The nginx log then says this: *323 directory index of "/usr/share/nginx/html/" is forbidden.
I've Googled around and came up with some possible solutions like this, but I've checked the www.conf and it seems to listen to php-fpm already. Any ideas on where to look for the cause?
Asitis
  • 569
This is an nginx configuration issue, and not a PHP/Magento one.
NGINX is trying to do a directory listing and not passing things properly to Magento in the backend I think.
That's why it gives the error it does - it can't do a directory listing of the docroot because you haven't enabled that functionality, and you likely wouldn't need to if you hand it off to Magento properly and have correct redirects, processing, etc. in the NGINX side of things.
Thomas Ward
  • 78,878
