23
I have Ubuntu 11.10 and installed php5-fpm and I want to configure nginx. I want to use unix sockets instead of tcp sockets but I couldn't find the
 /var/run/php5-fpm.sock
I have looked also
/tmp/php5-fpm.sock
Where is php5-fpm.sock file? I also tried
locate php5-fpm.sock
but I couldn't find anything. Note: php5-fpm is working . I have started as a service http://blog.bigdinosaur.org/wordpress-on-nginx/ http://blog.nas-admin.org/?p=25
Gok Demir
  • 333
In the default configuration before 12.10 Quantal, PHP FPM is set to listen on TCP port 9000 on address 127.0.0.1. This can be changed in /etc/php5/fpm/pool.d/www.conf.
Look for the line:
listen = 127.0.0.1:9000
and change it to something like:
listen = /var/run/php5-fpm.sock
After doing so, restart PHP FPM:
sudo /etc/init.d/php5-fpm restart
(note: reload is broken on Oneiric as it sends a HUP signal to php5-fpm which is wrong. It's fixed in Precise by sending USR2, bugreport).
Note: as mentioned by @SpamapS (palingdrome :D), newer releases use Unix sockets by default, not the tcp socket. See this Launchpad comment, it got changed in 12.10 Quantal.
Lekensteyn
  • 178,446
Unfortunately this method is old and will no longer work . OLD
Now a days you need to use
sudo service php5-fpm restart
In place of restart you may also use; start, stop and reload.
Case
  • 111
