17
I'm trying to create a bootable USB stick of ubuntu-11.10-desktop-i386.iso using usb-creator-gtk on my ThinkPad X220. Usb-creator-gtk appears to work OK, but the resulting stick fails to boot either of my laptops. I tried two different USB sticks. Boot just shows a blinking cursor.
If I mount the USB stick, I see it has 729M of data on it.
One more clue: After usb-creator-gtk exits, the activity light on my USB drive continues to blink for a minute or so, and even after that's done, /media/XXXX-XXXX and /tmp/tmpXXXXXX remain mounted. I have been manually umounting them before pulling out the stick.
Is there any way to get debug output from usb-creator-gtk? Or is there a straightforward command-line alternative to usb-creator-gtk that would offer more debugging options?
UPDATE: In syslog, I noticed the error:
usb-creator-gtk[xxxxx]: segfault at 4 ip xxxxxxxxxxxxxxxx sp xxxxxxxxxxxxxxxx error 6 in libdbus-1.so.3.5.7[xxxxxxxxxxxx+xxxxx]
Turns out this is ubuntu bug #875758.
Is there an alternative to usb-creator-gtk? Ideally, a bash recipe that would help me isolate the problem and work around it?
muru
  • 207,228
Joe
  • 1,099
  • Identify device (/dev/xxx) and unmount device
  • Device should be in FAT32 if not:
    sudo mkdosfs -n 'USB-LABEL' -I /dev/xxx -F 32
Mount the iso file and copy content to USB device:
sudo mkdir /media/iso
sudo mount -o loop /path/to/ubuntu.iso /media/iso
cp -a /media/iso/. /USBMOUNTPOINT/
Make the device bootable:
sudo apt-get install syslinux mtools
syslinux -s /dev/sdd1
Rename the isolinux directory to syslinux and copy config:
mv /media/xxx/isolinux /media/xxx/syslinux
mv /media/xxx/syslinux/isolinux.cfg /media/xxx/syslinux/syslinux.cfg
Reboot your pc and change the boot-order in bios to USB. Now your ubuntu usb flash drive will booted up and you can install it.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
yilmi
  • 1,282
mkusb-nox wraps a safety belt around dd
It is possible to use dd 'naked', but I would discourage you to do it, because it is risky.
dd if=file.iso of=/dev/sdx
dd is very powerful and does what you tell it to do without any questions, even if you tell it to overwrite your family pictures. A simple typing error is enough ...
mkusb-nox is a tool, that works in text screens and terminal windows (nox: no X graphics).
It uses dd under the hood to clone the content of a hybrid iso file to a target block device (USB drive, memory card ...). Most current linux iso files are hybrid iso files. You can say that mkusb-nox (as well as mkusb with a GUI) 'wraps a safety belt' around dd.
mkusb-nox uses an extraction method to create install drives for Windows.
See these links,
Edit: You can use dus (mkusb-dus) in text mode
sudo add-apt-repository universe  # only for standard Ubuntu
sudo add-apt-repository ppa:mkusb/ppa # and press Enter sudo apt-get update sudo apt-get install dus mkusb-nox usb-pack-efi
sudodus
  • 47,684
