I have a fresh install of Ubuntu 16.04 on a brand new Dell XPS 13 9365 but the wireless isn't working ( however ethernet is ). I've looked at numerous forum posts for possible fixes and have tried a number of things with no success, including:
  • purging/installing bcmwl-kernel-source
  • sudo service network-manager restart
  • disabling Secure Boot
  • using proprietary drivers and sudo apt-get upgrade
but nothing has worked. here's potentially relevant info:
sudo lshw -C network
  *-network UNCLAIMED
       description: Network controller
       product: Intel Corporation
       vendor: Intel Corporation
       physical id: 0
       bus info: pci@0000:3c:00.0
       version: 78
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress cap_list
       configuration: latency=0
       resources: memory:c8a00000-c8a01fff
  *-network
       description: Ethernet interface
       physical id: 2
       logical name: enxd481d70b47bb
       serial: d4:81:d7:0b:47:bb
       capacity: 1Gbit/s
       capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8152 driverversion=v1.08.2 duplex=full ip=10.1.10.41 link=yes multicast=yes port=MII speed=1Gbit/s
ifconfig
enxd481d70b47bb Link encap:Ethernet  HWaddr d4:81:d7:0b:47:bb
          inet addr:10.1.10.41  Bcast:10.1.10.255  Mask:255.255.255.0
          inet6 addr: 2603:300a:50f:4500::82c0/128 Scope:Global
          inet6 addr: fe80::c25f:25b2:a543:41ab/64 Scope:Link
          inet6 addr: 2603:300a:50f:4500:3820:773e:d850:bf44/64 Scope:Global
          inet6 addr: 2603:300a:50f:4500:247e:8cc3:8c88:768c/64 Scope:Global
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:3297 errors:0 dropped:0 overruns:0 frame:0
          TX packets:3088 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1520006 (1.5 MB)  TX bytes:435638 (435.6 KB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:1291 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1291 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:116776 (116.7 KB)  TX bytes:116776 (116.7 KB)
iwconfig
lo        no wireless extensions.
enxd481d70b47bb  no wireless extensions.
cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
lspci -knn | grep Net -A2
3c:00.0 Network controller [0280]: Intel Corporation Device [8086:24fd] (rev 78)
    Subsystem: Intel Corporation Device [8086:8050]
    Kernel modules: wl
cat /etc/NetworkManager/NetworkManager.conf
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
[ifupdown]
managed=false
Zanna
  • 72,312
Nick Briz
  • 253
Your device is not covered until kernel version 4.8. Ubuntu 16.04 uses kernel version 4.4.
You could either install Ubuntu 16.10 or else upgrade your existing install to a 4.8 kernel. In the latter case, connect to the internet by some other way and install the 4.8 kernel
sudo apt update
sudo apt install linux-generic-hwe-16.04-edge
You should also remove the incorrect Broadcom driver:
sudo apt-get purge bcmwl-kernel-source
You also need firmware for this device
wget http://mirrors.kernel.org/ubuntu/pool/main/l/linux-firmware/linux-firmware_1.161_all.deb
sudo dpkg -i linux-firmware_1.161_all.deb
Reboot and the wireless device should work.
chili555
  • 61,330
