I installed Tensorflow with GPU support and want to check it if I really installed it properly.
I tried simple check provided by Tensorflow which says:
$ python
>>> import tensorflow as tf
>>> hello = tf.constant('Hello, TensorFlow!')
>>> sess = tf.Session()
>>> print(sess.run(hello))
Hello, TensorFlow!
>>> a = tf.constant(10)
>>> b = tf.constant(32)
>>> print(sess.run(a + b))
42
it produced the same results. However I faced many errors during the installation and solved them somehow. Is it really enough to make sure that I can go on and use Tensorflow? Thank you
Thomas
  • 6,433
To check if you're using the gpu with tensorflow, run the following on a python console:
sess = tf.Session(config=tf.ConfigProto(log_device_placement=True))
and it'll dump a verbose description of your gpu
Amith KK
  • 13,547
Here are requirements from NVIDIA for using NVIDIA GPU with tensorflow:
The GPU-enabled version of TensorFlow has the following requirements:
64-bit Linux
Python 2.7
NVIDIA CUDA® 7.5 (CUDA 8.0 required for Pascal GPUs)
NVIDIA cuDNN v4.0 (minimum) or v5.1 (recommended)
You will also need an NVIDIA GPU supporting computer capability 3.0 or higher.
See more at: www.nvidia.com/object/gpu-accelerated-applications-tensorflow-installation.html#sthash.eaN8w5me.dpuf
..from http://www.nvidia.com/object/gpu-accelerated-applications-tensorflow-installation.html
In an earlier question, you stated your system has an NVIDIA GeForce GTX 980M: Need a solution to a blinking screen
Manufacturer specs show "CUDA: yes" ( from geforce.com/hardware/notebook-gpus/geforce-gtx-980m/specifications ).
"Yes" is not a number. Chances are there was only one number when the card was made ie "1".
The only way to know for sure if the GPU option is compatible with your system is to try. However, the outcome is not in your favor. CPU may be your only stable option.
best wishes
