I wanted to install ubuntu is along side windows but my windows were erased somehow. Anyway, I have windows cd but not partition to install it in dual-boot. SO can u pls tell me how I can partition my drive. And pls don't tell me to install windows completely over ubuntu and then install ubuntu ok. BTW thank u.
Asked
Active
Viewed 29 times
- For windows to be installed alongside ubuntu first you need to make the partition of the format NTFS in your ubuntu
- you can do it using gparted application in ubuntu.
- After this start booting your windows.
then install windows on that particular NTFS partition.
for more info go here How do I install Windows 7 alongside a pre-existing Ubuntu installation?
Akhil Varma
- 391
You can't create a partition on the existing drive if it is mounted. You need to create a live usb and boot into the live Ubuntu. Then follow these steps:
- Open terminal,
ctrl+alt+t. - Type
sudo gparted. - Resize your drive.
- Set the format's for the new unallocated memory space.
- Reboot back into your normal Ubuntu.
Then follow this to install windows on top of your new partition.
Sourav Badami
- 176
- 6
