I am running Kubuntu 16.04, for which I recently purchased a MMO mouse with many extra buttons (the UtechSmart Venus to be specific).
As those buttons would be of good use, I wanted to map some of them to things as Volume Up / Volume Down / Pause-Play, etc. I started doing so under System Settings -> Shortcuts and it worked fine.
The problem is, the bindings are mapped to numbers (e.g. 1 is Volume Up), which in turn also happen on the keyboard. This is undesired!
  • Is there a way to uniquely map the mouse extra buttons without interfering with the keyboard keys?
  • What are other customization options for custom key bindings for the mouse under (K)ubuntu?
I came across https://sourceforge.net/projects/kbmaster/ , but was wondering if there was a way to avoid it. Also not sure if it will work with a mouse instead of a keyboard.
I would simply use xbindkeys , it can bind nearly anything to a key/button press ( if you combine it with xautomation can make mouse button clicks from keyboard for example).
If you feel uncomfortable with config files maybe you can try using xbindkeys-config (GUI).
Also if your mouse buttons are not recognized, you probably need to use the evdev driver. Check this Ubuntu wiki page for more info.
Hope it helps.
dgonzalez
  • 7,310
