i've been googling this issue for the better part of a day with no success. i'm tring to connect to wifi using nmcli. i've got a connection created using my wifi device:
% nmcli c
NAME UUID TYPE DEVICE
Wired connection 1 89fdde8a-22e1-3c03-8b36-8299f2e95d43 802-3-ethernet enp0s10
Wi-Fi connection 1 826416aa-2030-4984-9685-8962857f59d9 802-11-wireless --
% nmcli c show "Wi-Fi connection 1"
connection.id: Wi-Fi connection 1
connection.uuid: 826416aa-2030-4984-9685-8962857f59d9
connection.interface-name: wlp3s0
but when i try to bring it up i get this:
% sudo nmcli c up "Wi-Fi connection 1"
Error: Connection activation failed: No suitable device found for this connection.
since "nmcli connection show" clearly shows that connection being associated with wlp3s0, i can only assume the reason is that NetworkManager thinks the device is "unavailable"
% nmcli d
DEVICE TYPE STATE CONNECTION
enp0s10 ethernet connected Wired connection 1
wlp3s0 wifi unavailable --
lo loopback unmanaged --
most people's issues with this seem to be solved with "rfkill unblock wifi". however, even after doing this, and restarting NetworkManager, i'm still unable to connect to wifi...
% rfkill unblock wifi
% rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
2: brcmwl-0: Wireless LAN
Soft blocked: no
Hard blocked: no
% sudo systemctl restart NetworkManager
% nmcli d
enp0s10 ethernet connected enp0s10
in /var/log/syslog, i see these interesting lines:
Dec 30 15:55:24 providence NetworkManager[3851]: <info> [1483142124.5273] (wlp3s0): using nl80211 for WiFi device control
Dec 30 15:55:24 providence NetworkManager[3851]: <info> [1483142124.5299] manager: (wlp3s0): new 802.11 WiFi device (/org/freedesktop/NetworkManager/Devices/0)
Dec 30 15:55:24 providence kernel: [ 1498.556769] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
Dec 30 15:55:24 providence NetworkManager[3851]: <info> [1483142124.5359] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
what the heck does "reason 'managed'" mean??
i've also tried disabling power management for wifi in NetworkManager by dropping this into /etc/NetworkManager/conf.d/:
[connection]
wifi.powersave = 2
upon rebooting, the interface is blocked again...
i must be missing something really obvious? because this is crazy...
ps. it's worth pointing out that this gives me the expected list of wifi networks in range, seemingly indicating that the hardware is fine:
% sudo ifconfig wlp3s0 up
% sudo iwlist wlp3s0 scan
