I am running Ubuntu 20.04 with the low latency kernel for Ubuntu Studio. (To be really specific I actually installed Kubuntu 20.04, then install Ubuntu Studio, and got the low latency kernel that way; I doubt any of that matters, just trying to be thorough.)
I have the Intel 7260.HMW Dual Band Wireless-AC 7260 Network Adapter PCI Express Half Mini Card 802.11 b/a/g/n/ac - Here's a link to the specific card I bought on Amazon: https://www.amazon.com/gp/product/B00MV3N7UO/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
The problem I am having is that every few hours my wifi would get disconnected/deactivated and I would have no way to restart it except to restart my system. Just loggin in/out would not work. I tried all sort of terminal command to restart NetworkManager, reload kernel moduls, etc. but nothing worked.
A slight positive, whenever I get disconnected I am able to plug in a usb wifi adaptor and almost instantly am once again connected to the internet through that, but I still cannot use my internal wifi card until I restart my system.
Another thing I noticed, after much fiddling with NetworkManager, (and adding the Gnome NetworkManager, which seemed somewhat better than the default KDE/Plasma version) was that before wifi became completely unresponsive other smaller issues would show up in NetworkManager. The first thing was that all of the networks, except the one I was connected to, would disappear from the list. After that, certain options would be grayed out, like "Connect to hidden wifi network," "Enable networking," "Enable wifi;" not sure about other options. Soon after, wifi would just become completely unresponsive. The system would be completely unable to even detect that I had a wifi device installed.
I also noticed that if I ran nmcli device wifi list when the non-connected networks would disappear from the list in the NetworkManager gui, they would often re-appear, and this seemed to stave off the problem of wifi turning off -- but it would still turn off eventually, so this was not a viable solution. (I even made a cron job to run nmcli device wifi list every 20 seconds, so I wouldn't have to keep checking and running it manually. This did not solve the problem either.)
In "/etc/NetworkManager/conf.d" I had one file, "default-wifi-powersave-on.conf" with the following contents:
[connection]
wifi.powersave = 3
I deleted that file, and replaced it with one called "wifi-powersave.conf" with the follwing (eventually adding the two extra settings, one for iwlwifi and one for wlp3s0, just because I was trying to be thorough, and try everything I could think of):
[connection]
# Values are 0 (use default), 1 (ignore/don't touch), 2 (disable) or 3 (enable).
wifi.powersave = 2 [This did not seem to have an effect.]
iwlwifi.powersave = 2 [This may not have an effect.]
wlp3s0.powersave = 2 [This might do it!]
My original kernel was 5.4, but got upgraded during a normal suggested upgrade to 5.42. After reading a few things that seemed to work for others, I switched kernels, first to 5.7.10 then 5.6.7., all of them low latency. That didn't help
Then tried adding the following to etc/modprobe.d/blacklist.conf: (Because of a post about someone else with a 7260, on a different distro, who added that line, plus a line "blacklist acer_wmi" and it worked. I don't have and Acer, but a ThinkPad T430, so I just added the one line.)
blacklist btusb
Didn't fix the problem.
Then I removed the blacklist btusb, and instead tried modifying the iwlwifi.conf, in the same folder, adding the following options.
options iwlwifi bt_coex_active=0
options iwlwifi power_save=0
options iwlmvm power_scheme=1
options iwlwifi d0i3_disable=1
options iwlwifi uapsd_disable=1
And here's the result of sudo lshw -C network done at various points of my wifi functionality:
When fully functional
*-network
description: Wireless interface
product: Wireless 7260
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlp3s0
version: bb
serial: 7c:5c:f8:dc:f4:f1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=5.4.0-40-lowlatency firmware=17.3216344376.0 ip=172.20.20.20 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:34 memory:f1c00000-f1c01fff
When starting to fail - Notice "bus_master" is missing from capabilities
*-network
physical id: 0
version: bb
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=5.4.0-40-lowlatency firmware=17.3216344376.0 latency=0 link=no multicast=yes wireless=IEEE 802.11
resources: irq:33 memory:f1c00000-f1c01fff
When not working - Now even more missing from capabilities; also description is now "Network controller" not "Wireless interface"
*-network UNCLAIMED
description: Network controller
physical id: 0
version: bb
width: 64 bits
clock: 33MHz
configuration: latency=0
resources: memory:f1c00000-f1c01fff
That's about it. Of course I tried all the simple stuff like trying to restart NetworkManger, in both of the following ways:
sudo systemctl restart NetworkManager
sudo service network-manager restart
I also tried removing and reloading the wifi drivers:
sudo modprobe -r iwlwifi && sudo modprobe iwlwifi
So, that is everything that I've tried. I also found this tidbit here: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi#d_3165_and_3168_support
On this page it states:
7260, 3160, 7265, 7265D, 3165 and 3168 support
Those devices will not be supported by the newest firmware versions: the last firmware that was released for 3160, 7260 and 7265 is -17.ucode. Bug fixes will be ported to -17.ucode.
Now, does this mean that these devices will no longer be usable in linux?
By the way, I am able to easily change wifi cards in my laptop. If there is a card out there, half pci size, that would be excellent for use in my laptop, and will actually work, I'd like to know about that! I do plan on using this computer with Kali as well, so I'd like the card to be really fast and good for normal stuff, but also have all the features needed by Kali. I thought this one would fit the bill, if I could just get it to work. (Would ndiswrapper work, perhaps?)
I've noticed a LOT of other similar posts, both with the identical Intel card and with other Intels, so if we can find a fix, this would probably also help many others as well.
EDIT: Since posting the above I have tried more things, and will share them here now.
While I was switched to 5.6.7-lowlatency I tried to install backport-iwlwifi-dkms but it did not install properly (I am sorry I forget the error message). So, I then reverted back to 5.4.0-42-lowlatency, deleted the other higher kernels I had tried, and then installed backport-iwlwifi-dkms successfully without error. This however did nothing to solve my wifi problem, so I later uninstalled it.
At this point I had reverted all of my changes back to what the system was originally, except for the changes I made to iwlwifi.com, which didn't seem to help or hurt, or really affect anything in any way.
I was now at a loss for what to do to proceed, as I had tried just about everything. I was thinking of trying ndiswrapper, but some info I had found seemed to indicate that my wifi chipset would not work with that, so I am putting that idea on the shelf for a while.
I then tried running 'tail -f /var/log/syslog' just so I could keep tabs of what was happening when wifi failed. Here is some of the output:
Jul 30 11:03:34 ENCOM-T430 systemd[1]: Starting Network Manager Script Dispatcher Service...
Jul 30 11:03:34 ENCOM-T430 dbus-daemon[582]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jul 30 11:03:34 ENCOM-T430 systemd[1]: Started Network Manager Script Dispatcher Service.
Jul 30 11:03:43 ENCOM-T430 systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Jul 30 11:05:14 ENCOM-T430 kernel: [ 2511.456439] iwlwifi 0000:03:00.0: Failed to wake NIC for hcmd
Jul 30 11:05:14 ENCOM-T430 kernel: [ 2511.457393] iwlwifi 0000:03:00.0: Error sending STATISTICS_CMD: enqueue_hcmd failed: -5
Jul 30 11:05:15 ENCOM-T430 kernel: [ 2512.960634] iwlwifi 0000:03:00.0: Failed to wake NIC for hcmd
Jul 30 11:05:15 ENCOM-T430 kernel: [ 2512.961409] iwlwifi 0000:03:00.0: Error sending STATISTICS_CMD: enqueue_hcmd failed: -5
Jul 30 11:05:16 ENCOM-T430 kernel: [ 2512.981002] iwlwifi 0000:03:00.0: Failed to wake NIC for hcmd
Jul 30 11:05:16 ENCOM-T430 kernel: [ 2512.981039] iwlwifi 0000:03:00.0: Error sending STATISTICS_CMD: enqueue_hcmd failed: -5
Jul 30 11:05:19 ENCOM-T430 kernel: [ 2516.454834] iwlwifi 0000:03:00.0: Failed to wake NIC for hcmd
Jul 30 11:05:19 ENCOM-T430 kernel: [ 2516.454900] iwlwifi 0000:03:00.0: Error sending STATISTICS_CMD: enqueue_hcmd failed: -5
Jul 30 11:05:21 ENCOM-T430 kernel: [ 2518.956560] iwlwifi 0000:03:00.0: Failed to wake NIC for hcmd
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2518.956655] iwlwifi 0000:03:00.0: Error sending STATISTICS_CMD: enqueue_hcmd failed: -5
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2518.975830] iwlwifi 0000:03:00.0: Failed to wake NIC for hcmd
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2518.975945] iwlwifi 0000:03:00.0: Error sending STATISTICS_CMD: enqueue_hcmd failed: -5
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549253] ------------[ cut here ]------------
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549258] Timeout waiting for hardware access (CSR_GP_CNTRL 0xffffffff)
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549317] WARNING: CPU: 2 PID: 24 at drivers/net/wireless/intel/iwlwifi/pcie/trans.c:2066 iwl_trans_pcie_grab_nic_access+0x1f9/0x230 [iwlwifi]
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549319] Modules linked in: vboxnetadp(OE) vboxnetflt(OE) vboxdrv(OE) intel_rapl_msr rfcomm cmac algif_hash algif_skcipher af_alg bnep uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev btusb btrtl mc btbcm btintel bluetooth ecdh_generic ecc intel_rapl_common x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel iwlmvm mac80211 kvm libarc4 iwlwifi snd_hda_codec_hdmi intel_cstate intel_rapl_perf snd_hda_codec_realtek snd_hda_codec_generic snd_seq_midi snd_seq_midi_event snd_hda_intel snd_intel_dspcfg snd_hda_codec joydev input_leds snd_hda_core snd_hwdep serio_raw snd_pcm snd_rawmidi cfg80211 wmi_bmof thinkpad_acpi nvram ledtrig_audio snd_seq snd_seq_device snd_timer snd soundcore mac_hid binfmt_misc sch_fq_codel cuse parport_pc ppdev lp parport ip_tables x_tables autofs4 crct10dif_pclmul crc32_pclmul ghash_clmulni_intel i915 aesni_intel crypto_simd cryptd glue_helper psmouse i2c_algo_bit ahci drm_kms_helper sdhci_pci libahci i2c_i801 cqhci
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549370] syscopyarea sdhci lpc_ich sysfillrect sysimgblt fb_sys_fops e1000e drm wmi video
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549381] CPU: 2 PID: 24 Comm: ksoftirqd/2 Tainted: G OE 5.4.0-42-lowlatency #46-Ubuntu
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549382] Hardware name: LENOVO 2344BZU/2344BZU, BIOS G1ETC2WW (2.82 ) 08/07/2019
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549396] RIP: 0010:iwl_trans_pcie_grab_nic_access+0x1f9/0x230 [iwlwifi]
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549400] Code: 26 d7 49 8d 57 08 bf 00 20 00 00 e8 51 13 ae d5 e9 30 ff ff ff 89 c6 48 c7 c7 30 a1 a0 c0 c6 05 25 f0 02 00 01 e8 62 0a ac d5 <0f> 0b e9 eb fe ff ff 49 8b 7c 24 38 48 c7 c1 98 a1 a0 c0 31 d2 31
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549402] RSP: 0018:ffffb5714013fca0 EFLAGS: 00010086
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549404] RAX: 0000000000000000 RBX: ffffb5714013fcd8 RCX: 0000000000000006
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549406] RDX: 0000000000000007 RSI: 0000000000000082 RDI: ffff9717564978c0
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549407] RBP: ffffb5714013fcc8 R08: 0000000000000001 R09: 00000000000003f4
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549409] R10: 0000000000014674 R11: 0000000000000004 R12: ffff971748138018
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549410] R13: 0000000000000000 R14: ffff971748139e4c R15: 00000000ffffffff
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549413] FS: 0000000000000000(0000) GS:ffff971756480000(0000) knlGS:0000000000000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549414] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549416] CR2: 00007f5fa2462000 CR3: 00000001c600a004 CR4: 00000000001606e0
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549418] Call Trace:
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549434] iwl_read_prph+0x39/0x90 [iwlwifi]
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549448] iwl_trans_pcie_log_scd_error+0x14c/0x220 [iwlwifi]
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549461] iwl_pcie_txq_stuck_timer+0x49/0x70 [iwlwifi]
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549473] ? iwl_pcie_txq_inc_wr_ptr+0x110/0x110 [iwlwifi]
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549481] call_timer_fn+0x32/0x160
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549486] run_timer_softirq+0x19c/0x4f0
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549497] ? iwl_pcie_txq_inc_wr_ptr+0x110/0x110 [iwlwifi]
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549503] ? __switch_to_asm+0x34/0x70
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549506] ? __switch_to_asm+0x40/0x70
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549509] ? __switch_to_asm+0x34/0x70
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549512] ? __switch_to_asm+0x40/0x70
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549515] ? __switch_to_asm+0x34/0x70
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549518] ? __switch_to_asm+0x40/0x70
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549522] ? __switch_to+0x7f/0x490
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549526] __do_softirq+0xe1/0x308
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549533] run_ksoftirqd+0x2b/0x40
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549539] smpboot_thread_fn+0xfc/0x1f0
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549542] kthread+0x104/0x140
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549546] ? sort_range+0x30/0x30
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549548] ? kthread_park+0x90/0x90
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549552] ret_from_fork+0x35/0x40
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549556] ---[ end trace 3b3350bf6ae75ff1 ]---
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549563] iwlwifi 0000:03:00.0: iwlwifi transaction failed, dumping registers
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549569] iwlwifi 0000:03:00.0: iwlwifi device config registers:
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549907] iwlwifi 0000:03:00.0: 00000000: 08b18086 00100000 028000bb 00000000 00000004 00000000 00000000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549912] iwlwifi 0000:03:00.0: 00000020: 00000000 00000000 00000000 44708086 00000000 000000c8 00000000 00000100
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549917] iwlwifi 0000:03:00.0: 00000040: 00020010 10008ec0 001b0c10 0006ec11 10110000 00000000 00000000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549921] iwlwifi 0000:03:00.0: 00000060: 00000000 00080812 00000005 00000000 00010001 00000000 00000000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549925] iwlwifi 0000:03:00.0: 00000080: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549928] iwlwifi 0000:03:00.0: 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549933] iwlwifi 0000:03:00.0: 000000c0: 00000000 00000000 c823d001 0d000000 00804005 00000000 00000000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549936] iwlwifi 0000:03:00.0: 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549941] iwlwifi 0000:03:00.0: 00000100: 14010001 00100000 00000000 00462031 000030c1 00002000 00000014 40000001
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549945] iwlwifi 0000:03:00.0: 00000120: 0000000f f1c00024 00000000 00000000 00000000 00000000 00000000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549949] iwlwifi 0000:03:00.0: 00000140: 14c10003 ffdcf4f1 7c5cf8ff 15410018 00000000 0001000b 0141cafe 00f01e1f
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549952] iwlwifi 0000:03:00.0: iwlwifi device memory mapped registers:
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.549998] iwlwifi 0000:03:00.0: 00000000: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550002] iwlwifi 0000:03:00.0: 00000020: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550009] iwlwifi 0000:03:00.0: iwlwifi device AER capability structure:
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550047] iwlwifi 0000:03:00.0: 00000000: 14010001 00100000 00000000 00462031 000030c1 00002000 00000014 40000001
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550050] iwlwifi 0000:03:00.0: 00000020: 0000000f f1c00024 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550054] iwlwifi 0000:03:00.0: iwlwifi parent port (0000:00:1c.1) config registers:
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550244] iwlwifi 0000:00:1c.1: 00000000: 1e128086 00100407 060400c4 00810010 00000000 00000000 00030300 200000f0
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550248] iwlwifi 0000:00:1c.1: 00000020: f1c0f1c0 0001fff1 00000000 00000000 00000000 00000040 00000000 00020207
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550252] iwlwifi 0000:00:1c.1: 00000040: 01428010 00008000 00110000 02123c12 70110042 000cb200 01480000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550256] iwlwifi 0000:00:1c.1: 00000060: 00000000 00000016 00000000 00000000 00010002 00000000 00000000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550260] iwlwifi 0000:00:1c.1: 00000080: 00019005 fee00258 00000000 00000000 0000a00d 21f317aa 00000000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550264] iwlwifi 0000:00:1c.1: 000000a0: c8020001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550268] iwlwifi 0000:00:1c.1: 000000c0: 00000000 00000000 00000000 00000000 01000000 00000b02 81118000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550272] iwlwifi 0000:00:1c.1: 000000e0: 00000300 00000000 00000001 00000000 00000000 00000000 08050f87 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550276] iwlwifi 0000:00:1c.1: 00000100: 00000000 00000000 00000000 00060011 000011c1 00002000 00000000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550280] iwlwifi 0000:00:1c.1: 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550284] iwlwifi 0000:00:1c.1: 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550288] iwlwifi 0000:00:1c.1: 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550291] iwlwifi 0000:00:1c.1: 00000180: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550295] iwlwifi 0000:00:1c.1: 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550299] iwlwifi 0000:00:1c.1: 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550303] iwlwifi 0000:00:1c.1: 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.550306] iwlwifi 0000:00:1c.1: 00000200: 00000000 00000000 00000000
Jul 30 11:05:22 ENCOM-T430 kernel: [ 2519.607070] iwlwifi 0000:03:00.0: Queue 10 is active on fifo 2 and stuck for 10000 ms. SW [204, 217] HW [90, 90] FH TRB=0x05a5a5a5a
Jul 30 11:05:24 ENCOM-T430 kernel: [ 2521.456338] iwlwifi 0000:03:00.0: Failed to wake NIC for hcmd
Now it's back to searching for something based upon this new information. If anyone out there has any thoughts, ideas, or words of kind encouragement at this point, I would really appreciate it. Also, if anyone can recommend a really good half-pci wifi card I can replace this one with, with all the features necessary for Kali as well, I would welcome that too!
