I've tried the solution from this question, but even with exfat-fuse and exfat-utils installed, I can't mount my SDXC card (formatted in my Canon T3i camera).
ls -l /dev/sd* reports:
brw-rw---- 1 root disk 8, 0 Dec 29 17:10 /dev/sda
brw-rw---- 1 root disk 8, 1 Dec 29 16:14 /dev/sda1
brw-rw---- 1 root disk 8, 2 Dec 29 16:42 /dev/sda2
brw-rw---- 1 root disk 8, 5 Dec 29 16:14 /dev/sda5
brw-rw---- 1 root disk 8, 16 Dec 29 17:16 /dev/sdb
I do note that I'm not seeing /dev/sdb1.
fdisk -l /dev/sdb reports:
You must set cylinders.
You can do this from the extra functions menu.
Disk /dev/sdb: 0 MB, 65536 bytes
255 heads, 63 sectors/track, 0 cylinders, total 128 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/sdb1 32768 125171711 62569472 7 HPFS/NTFS/exFAT
Again, I note a couple things: I'm told I need to set cylinders, which I'm not sure how to do; and I see that the partition starts at 32768 instead of 0 or thereabouts.
The card mounts fine on my Windows 7 system, and in my camera. I tried formatting it NTFS on my Windows box but my camera rejected it, so I did a low-level format with the camera to get things back to square one.
