12
I did a clean install of 13.04 and now I'm having a hard time mounting my SD card. I had it working on my old system, which was also 13.04 but I had upgraded from 12.04. I can't figure out how to get it working now.
I tried this on my laptop and this is the result. Any ideas how I can fix this?
jay@jay-K55VD:~$ sudo apt-get install fuse-exfat exfat-utils Reading package lists... Done Building dependency tree
Reading state information... Done exfat-utils is already the newest version.
The following NEW packages will be installed: fuse-exfat 0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/26.4 kB of archives.
After this operation, 98.3 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
(Reading database ... 189001 files and directories currently installed.)
Unpacking fuse-exfat (from .../fuse-exfat_1.0.1-1_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/fuse-exfat_1.0.1-1_i386.deb (--unpack): trying to overwrite '/usr/share/man/man8/mount.exfat-fuse.8.gz',
which is also in package exfat-fuse 1.0.1-1 Processing triggers for man-db ...
Errors were encountered while processing: /var/cache/apt/archives/fuse-exfat_1.0.1-1_i386.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
jayb151
  • 203
just sudo apt-get install exfat-fuse exfat-utils on >= 13.04 it's already there
NOTE: do not install fuse-exfat with those ... that's a source of a package conflict
kares
  • 301
I received the same error using linux mint and followed the directions on this website.
http://blog.drastudios.com/2013/04/add-exfat-support-to-ubuntu.html
Basically, I downloaded and installed the .deb.
I did see errors but exfat now mounts fine and I can read/write to the 64gb micro.
