11
Hϵllo everyone. I have installed KDE on my Ubuntu 11.10 install. It's working nicely except for a couple of gripes with Dolphin file manager.
  1. It seems much slower than other file browsers. Any particular reasons for this? Any way how I could speed it up?
  2. I want to enable PDF preview for Dolphin. On googling a bit, I found a page that suggested following command:
     sudo apt-get install kdegraphics-strigi-plugins
    The preview doesn't work for me even after I ran the above command. How do I make it work?
Thanks.
Slower than other file browsers ?
What other ? Konqueror ? Krusader ?
The Dolphin is the default KDE file manager but you don't need to use it. System Settings > Default Applications > File Manager.
Thunbnails ?
Package: kdegraphics-thumbnailers
:~$ apt-cache show kdegraphics-thumbnailers
Description: graphics file format thumbnailers for KDE SC
 These plugins allow KDE software to create thumbnails for several
 advanced graphic file formats (PS, RAW).
Homepage: http://www.kde.org/
Commandline install:
sudo apt-get install kdegraphics-thumbnailers
Dolphin > Settings > Configure Dolphin > General > Previews: Show previews for PostScript, PDF and DVI Files
You may need to rise the "Do not create previews for" limit !
--- EDIT ----
Comment:
Slower than Nautilus, its GNOME brother.
I have not used the Nautilus but the developer /1/, /2/ is promising improved performance with the KDE 4.8 & Dolphin 2.0.
Comment:
...Though I don't get why I have to hit the "preview" button on toolbar for every directory I enter in. How can I make it the default behavior?
One way: Dolphin > View > Adjust View Properties. Press the F1 key, when the Dolphin is active, to get the Dolphin Handbook.
Another way /3/: Open the Dolphin in the ~/.kde/share/apps/dolphin/view_properties/global/ (*1) and turn the Icons/Details/Columns/Preview/... on/off. The settings are saved to the ~/.kde/share/apps/dolphin/view_properties/global/.directory file and used as the global defaults - IF the local folder does not have own .directory file with the overriding settings.
KDE .directory file:
The .directory file is a KDE folder view properties file. It contains the folder viewing settings for a directory in KDE. It includes settings such as icon positions and view mode (icon, list, etc.). Automatically created when the view settings of a folder are modified. Hidden by default.
(*1) If the ~/.kde/share/apps/dolphin/view_properties/global/ directory does not exist, you could make it.
More of the Dolphin: KDE UserBase /4/ and the Dolphin KDE Home /5/.
Links
  1. http://ppenz.blogspot.com/
  2. http://ppenz.blogspot.com/2011/08/introducing-dolphin-20.html
  3. http://www.kubuntuforums.net/showthread.php?55954-Solved-Dolphin-settings&s=3b900a05916fdf62051c6acedb4d9e7c
  4. http://userbase.kde.org/Dolphin
  5. http://dolphin.kde.org/index.html
guntbert
  • 13,475
user26687
  • 15,174
with installing kdegraphics-thumbnailers I had no success, but after I installed kio-fuse + kio-extras it worked again.
