Every time I (lid-closing) suspend Ubuntu, when I get back again, the volume of internal speakers do not wok. There is no sound at all. If I simply reboot into Windows (10) the problem is present there as well, and I can not play any sound.
I followed many discussions on this, in particular this one, where are explained some of the most common workaround that I followed to partially fix the original problem (only dummy output device listed in the sound options). Now the problem of no sound appears only after the suspension. In the same discussion, it is suggested to cold shutdown the system and then boot into Windows. This "fixes" the problem, but at the next suspension of Ubuntu it reappears.
What can I do to avoid this issue after every Ubuntu suspension?
EDIT: to update and add some more info to this not yet solved issue:
:~$ dpkg -l *alsa*
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un alsa <none> <none> (no description available)
ii alsa-base 1.0.25+dfsg- all ALSA driver configuration files
un alsa-oss <none> <none> (no description available)
ii alsa-utils 1.1.0-0ubunt amd64 Utilities for configuring and usi
un bluez-alsa <none> <none> (no description available)
ii gstreamer1.0-a 1.8.2-1ubunt amd64 GStreamer plugin for ALSA
un libesd-alsa0 <none> <none> (no description available)
un libsdl1.2debia <none> <none> (no description available)
